Question about Anne Klein Watches
Battery for 10/1553-5
What battery
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
I need a new battery
Most digital watches have "standard" batteries. Invariably all batteries have a number on them.All watch battery stockists have "equivalence lists" so that irrespective of brand of battery a "generic" battery of the same dimensions - diameter and thickness ( and voltage) can be found from a "stocked:"range.e.g.a battery that is 6.8mm diam and 2.6mm thick is variously known as a SR626SW, SB-AW, 280-39, RW329 or a 606 or a D377 - dependng on the "brand" of battery - It's common name is a 377 battery - and it will fit in - and work
Aug 30, 2010 | Michele Watches
Dead battery, how do I open?
I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
the details of the battery read on top the one currently inside it.
Jan 30, 2010 | Watches
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Watch going in reverse
There is no difference in watch batteries as they are produced by the certain standards. That means you have replaced the right battery.
The simplest solution would be re-replacing the battery. Just take the battery out and leave the watch without battery for 5 minutes, then put the battery back. Make sure the battery is fitted the right way (the + side usually facing up).
If this doesn;t help - let me know.
Rate, please.
Mar 23, 2009 | Watches
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Which watch battery do I use?
There are lots of different size button batteries for watches. I work in a clock shop where we change batteries in watches and I have had people bring the watches into me without batteries and it is really a guessing game. A lot of watches take a #377 battery. You can try that or take it to a place that changes watch batteries and let them figure it out.
Mar 08, 2008 | Watches
Watches Logo
44 people viewed this question
Top Anne Klein Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
