Ntv2401lcdfhd model nikai tv is not working problem is power supply i want 8leg smd ic no
2 Suggested Answers
SOURCE: Power supply AD-12014(I) two smd burned
223 both
Posted on Mar 02, 2010
I have no sound on my LED LG 42
i have the same tv only 6 mos old. Did u try your direct tv remote as well?
Nov 09, 2011 | LG Televison & Video
P50pdtv10a will not change channels stuck on channel 3
Hello
The system memory IC of your TV has damaged. This is one, which stores all the setting we have done with remote control, including channel memmory. This IC works in conjunction with the main system control IC. When we switch OFF or do any other adjustments with the tV, all the data will be stored in this IC, and tetreived from it to main system IC to process when we switch ON the TV. This is a non-volatile memory chip, ie, even the power is OFF, the data stored in it won't lost. This is a very small IC, can locate very near to main system control IC. Will have 8 solder terminals [normally], and ver cheap to buy too. Even though it is a very cheap and small one, the function of it in the circuit is great. In some Vizio sets, this IC will be of SMD [surface Mount Device] type, and on othere will be a DIL [Dual In Line] type pin confujuration. If your TVs memory is of first as stated above [SMD], replacing it will not be an easy job. If it is of second type, it can be replace easly.
Anyway, this is not a work that can be done without skill. If you have enough knldege in electronics, and have a concept of desoldering and soldering, have all soldering equipments with you, you can do this work by yourself at home. Otherwise you have to seek assistance from an experienced service technician. OK.
gopakumarg43
Oct 19, 2011 | Philips 60P8341 60" Rear Projection...
Hi there? My HP nc 6320 doesn't charge, I came to know that the IC in the power supply on the motherboard has shorted and it is dead, so what can I do? the power doesnt come into the motherboard but...
that is new mobo time, the charge or any reg chips bad.,
is the size of 1/8 of a baby's pinky finger nail
and has solder ball bottom SMD , tech.
you will never replace it and make it work again'
at home.
id give that a 1 to 1000 shot. success.
ever work SMD before?
new mOBO time, ask any tech, same answer.
have you removed all mobo modules first, to prove this case.?
any module can short, remove them all.
mine has 7 to pull.
http://www.pcdied.com/765-quad-core.jpg
Nov 12, 2017 | HP Compaq nc6320 Notebook
HI ! My name Igor from Saint -Petersburg -Russia ! I have problem with my lcd monitor ACER AL1716F model ! AC 220V voltage is up over normal and my monitor is dead ! I am open ...
You will need service manuals at this point, so please try downloading them from here:
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1716&kategoria=monitor&kat2=all
I hope they are close enough for the PCB you have.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Dec 19, 2010 | Acer AL1716 F Monitor
I have tv, the picture in not ok. i think the supply voltage is not good especially when i turn to other channels. the picture is just like moving or turn the side of the tv adjust about a centimeter and...
Hello
Your Tv has verical shift problem. It is not the supply problem. It can be got repaired. Sometimes it may be the fault of chroma Ic. In panasonic telivision the chroma section has an ic and it is surface mounted. We will call as SMDs. An SMD replacement needs special tools, which a normal sevice mechanic can't afford. So it is best for you to contact the authorised sevice center of Panasonic nearby.
Oct 18, 2010 | Panasonic TC-21S80RQ TV
I forget my security code of nikai tv
i want service code for nikai tv
May 16, 2010 | Televison & Video
No power -- TV will not turn on
This could be the power supply baord / Bad Caps/ They will be puffed up..
Or if the inverter board is bad** Inverter board lights the backlights.
Oct 30, 2008 | Vizio L32 32 in. LCD HDTV
LCD monitor dirty
please give me a power supply smd ic nomber please MODEL NO. HP VS17E
Jun 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
KP46V15 Convergence problem
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Gopal
Dec 10, 2007 | Sony KP-46V35 TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
