Canon ir2520 error codes 00024
Error codes 00024
2 Suggested Answers
  • 140 Answers
SOURCE: IR2520, error code E0002
it is related to fixing unit.
check your fixing unit.
Posted on Apr 18, 2011
Canon iR2520 ERROR CODE E000805
Hi. Are you sure the cables are connected correctly? If so maybe de fan is defective or the DC controller board is defective
Jan 21, 2018 | Canon Office Equipment & Supplies
Cannon it 2870 have error code E 00024-0000
Empty the waste toner .it's in the back of machine
Feb 11, 2017 | Canon IR 2870 Digital Copier RECONDITIONED
Canon ir2520 showing error code 808. What is the solution?
Code
E808-0000
Description
Fixing drive circuit failure
- The heater does not turn on. - A fixing drive motor failure was detected.
Remedy
- Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the fixing drive motor. - Replace the DC controller PCB. - Replace the power supply PCB.
Jul 05, 2016 | Canon Office Equipment & Supplies
Error code E000002 in Canon IR2520
Dear
it indicates fixing unit temp could not raised to predetermined value. The following steps may be taken to clear the error.
CLEAR>ENGIN>ERRLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector and AC Connector).
3.Replace the Fixing Assembly.
4.Replace the DC_CON PCB.
Thanks
Feb 13, 2015 | Canon Office Equipment & Supplies
I have a problem for my machine canon Image runner 2520 error code E000010
Hi
There appear to be several causes for this code and others with a second set of digits. The following site lists the error codes and possible corrections for your machine :--
Error Codes Canon iR2520
Each code can be viewed individually by using the drop down menu "Codes", and you can also get a Service Manual pdf (format) from this site for a small charge using the link near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 11, 2015 | Canon Office Equipment & Supplies
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Ir 3025 copier from canon. paper gets jammed with the error code 00024-001
haay this is aslam plz clean ur developer unit dont add toner. dyerect replace it.
Sep 29, 2013 | Computers & Internet
Canon ir3570 show error 00024
check for paper jammed in fuser assy, u need to reset error code by pressing smarthead then 2and 8 SAME TIME then smarthead should go into service mode press copier then function then err ok then off on
Feb 19, 2013 | Canon ImageRUNNER 3570 Copier/Printer
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Jun 30, 2010 | Canon Office Equipment & Supplies
67 people viewed this question
jasbo
jasbo
