Question about Bush Televison & Video
Reboot thomson freeview box
On the recording page it just shows undefined
SOURCE: My Thomson freeview recorder box
Marriott, You will find that it is only one recording that is causing this. This also happens to my box as well when we tape emerdale on a Monday. look through what has been taped and find out if the minutes used is correct for that programme. if not then you need to do the following in very quick procession.
Press the delete button and confirm as quickly as possible when you scan down the the programme that has not recorded correctly.
Hope this helps
Norrie
Posted on Oct 30, 2008
RFICKES
  • 51 Answers
SOURCE: unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Posted on Jan 03, 2009
SOURCE: Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Posted on Mar 04, 2009
  • 3 Answers
SOURCE: thomson dti 6300 freeview box will
What to do: if you have a solid amber light If the power light on the box will not change from solid Amber to solid Red then it is possible that a problem has occurred with the current in use software. Before attempting a fix, power the box off and on at the power socket and then wait at least 5 minutes for the solid RED lamp to appear.
If it still remains solid Amber and the box will not come out of standby to ON (Green light) then this can be corrected using the software revert procedure which is done using the box front panel buttons as follows:
1. Remove power to the unit by removing the power cable from the back of the box.
2. Wait 20 seconds and then restore the power cable while pressing the standby button repeatedly on the front panel of the box.
3. Release the standby button immediately when you see a lamp flash on the box's front display, and then immediately press the following front panel arrow buttons in this sequence:
- Menu
- OK
Note: you have to do this quickly and in sequence
4.The Orange light will flash and the STB will then reboot and should return with the previous version of software.
5. The box will now be running with the previous software version but it will automatically update with the latest version within approx 2 hours and you will be notified by message which will appear in the Message area within the Main Menu.
If you're still having problems please call 08444 159 159 and a member of the Technical Team will be happy to help.
Posted on May 06, 2009
  • 7 Answers
SOURCE: Thomson dti6300-16 won't record freeview channels....
maybe a defragged hard drive follow this procedure:
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Posted on Feb 15, 2010
After recording a programme last night on my thomson freeview box a flashing orange light came on. i have tried switching it off at the plug, but the flashing light is still there
Hi, a common problem with the thomson freeview boxes is capacitors leaking in the power supply, The ones that go usually are the two 1000uf capacitors. If any of the capacitors look deformed, ie the tops look domed in any way. I would change them , Handy if you know how to use a soldering iron. If you can use a soldering iron remember to put the new capacitor in the same way ( the wires are marked so you must put them in the same way round).
pete
Nov 27, 2010 | Thomson Televison & Video
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Oct 02, 2009 | Arris DCT2608
Thomson topupbox
hi i have sorted the problem i went on line of the make of the thomson freeview and their was other people with the same problem and they help me by reading their instrutions on their page now it is working .
May 04, 2009 | Thomson DTH8000 DVD Recorder
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
Mar 05, 2009 | Arris DCT2608
Jun 04, 2008 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
