I have a Jensen JER 422 universal remote and need to program it for my older Sanyo television. I can't seem to find the code(s) I need to program it. Unfortunately the remote control belongs to my roommate who lost the manual. I tried to go to the www.jensenremotes.com web site but it will not connect. Any help would be very much appreciated.
5 Other Users Have The Same Problem
Comment by jtacuba, posted on Jul 07, 2008
Tengo un problema para poder utilizar mi control JENSEN DC JER 422 SE DESPROGRAMO Y NO LO PUEDE UTIZAR YA QUE NO CUENTO CON EL MANUAL DE CODIGOS Y PODE UTILIZARLO EN UNA TV SAMSUNG
Comment by josimanu, posted on May 02, 2008
tenho um dvd cougar e não consigo programar o controle por falta do código.
o que faço?
Comment by Singlesix, posted on Jan 04, 2008
I have a model SSCOP2 Sylvania combo TV/VCR. Also, I have Jensen Universal 3 remote and would like to program them. Have no codes as the book is gone. Can you help me?
Ed Hofferber.
Comment by Guest, posted on Nov 22, 2007
i just bougth a universal renote control same model but it does not haver a users manual and i cant connect with the jensens page
Comment by Guest, posted on Nov 10, 2007
lost codes
Was this solution helpful? Show your Appreciation by rating it:
In order to program your TV:
1. Manually turn on your component.
2. Press and hold the component key you wish to program, in your case the TV key.
3. While holding down the component key press the four-digit code using the number keys (0-9) to enter it.
4. After the fourth number is entered, the illuminated ON-OFF key turns on. At this time, release the comonent key. If the illuminated ON-OFF key turns off, you have entered a valid code.
NOTE: For Sanyo TV it could be any of the 8 next codes:
1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
Good Luck !
Carlos Vallejo
Rating: 0%, 0 votes
Post a New problem for Jensen JER-422 4-Device Universal
Email this problem
Can you Help with these Remote Controls problems?
BD-512 REMOTE CONTROL
Teknique jumbo remote
Teknique Jumbo Universal Remote...
roofing...shingles
I need codes for a
