Question about Sharp AR-5320 Black and White Copier
SOURCE: it dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Posted on Nov 28, 2008
SOURCE: my copier AR-5320E is showing a number 4 and letter H
the fuser unit is not heating up
unplug the copier then plug back in
make sure the fuser area where you clear jams is latched down
close all doors
if this does not work your fuser lamp is burned out or a fuse has blown on the heater roller
You will have to call service
Posted on Jan 07, 2009
SOURCE: Password to avoid the unauthorized Use
Go to user settings or press the light exposure key and hold until toner sign, service..... starts to blink. Press % key for 5 sec and --- will appear . Enter 14 press print , --- will appear and enter your secret code and press print. Your code is stored. Now press the light key for 5 sec and the machine will return to normal mode but with --- on the display. Use your 3 code to unlock and it should read 0. Every time you switch on --- will always show and nobody except you will operate it. For more information on user codes, go to user's manual and read the 'user codes page'
Posted on Dec 01, 2009
SOURCE: AR-5320 Black and White Copier: new 5320e no photocpies but print out blank paper...
hi dear may you dont have put the origenal document proper or may be blank, just put writing side down on the glass or if u are using ADF put the writing side up side,
thanks
Posted on May 20, 2010
Jan 30, 2011 | Sharp AR-156 Copier
May 18, 2010 | Sharp AR-5320 Black and White Copier
Sep 25, 2009 | Sharp AR-156 Copier
Jul 16, 2009 | Sharp AR-5320 Black and White Copier
Feb 01, 2009 | ASUS K8V-MX Motherboard
Jan 20, 2009 | Sharp AR-5320 Black and White Copier
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
Nov 24, 2008 | Sharp AR-5320 Black and White Copier
Apr 07, 2008 | Sharp AR-5320 Black and White Copier
Nov 07, 2016 | Sharp AR-5320 Black and White Copier
183 people viewed this question
