Question about Vivitar ViviCam 3740 Digital Camera
Driver web 2555 - Vivitar ViviCam 3740 Digital Camera
My garmin nuvi 2555 says battery low and is plugged into the car
If the unit keeps displaying a pop up window saying that it will be shutting down with a count down timer then the problem is a loose USB port that keeps interrupting power to the unit. The reason why you receive a battery low warning is because the battery doesn't have a chance to charge because of the intermittent USB port. We see this problem all of the time on the Nuvi 11xx, 12xx, 13xx, 14,, and 25xx. We've repaired hundreds. Please see this link on why the problem happens and how we repair this problem so that it won't happen again.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 10, 2014 | Garmin nuvi 780 GPS
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
Ek dada,ek baap,ek pota,tino ka age 140 years.pota jitne month ka dada utne saal ka,pota jitne din ka baap utne week ka,tino ka age kya hoga?
Hahahaha, Aaala! Kafi sochna para, is tarha ho ga mere khyaal se;
140 Saal teenoN ki mila k banti hay;
Pota: 7Years
Baap: 49Years
Dada: 84Years
7+49+84 = 140 (Theek)
Pota kitnay Month ka = 7 x 12 = 84 => Dada ki umer in years (Theek)
Pota kitnay Din ka = 7 x 365 = 2555din => Baap ki umer in weeks [ (49x365) / 7 ] = 2555 (Ye be Theek)
Concerned, Nooh bin Sikander
Dec 18, 2010 | Computers & Internet
We bought a sears 'scope' 2555 at auction...no
To solve this problem is not going to be easy however you can pop into your local telescope store and tell them about your problem and they 'MUST' figure something out for sure.
Oct 17, 2009 | Sears 127474 Telescope
Which toner to use for the ricoh savin 2555? 5105D or 5770?
If you have a Savin 2555, you need type 5570.
If you have a Ricoh 1055, you need type 5105D.
They are both the same machine, however the toner cartridge is model specific. ie; use the Savin type toner for Savin machine only and Ricoh type toner for Ricoh. There is a difference between the cartridges and the way each fits the feed mechanism.
May 07, 2009 | Office Equipment & Supplies
Screen reading malfunction C 2555 has stopped copying
press 10871087 then 906 then start then execute. if it reappears call for service
May 06, 2009 | Office Equipment & Supplies
BizHub C252 - error Code C-2555 (Malfunction Detected)
C-2555 relates to a low toner density in the yellow imaging unit. I'm sure your daughter pressing buttons did not cause it.
I suggest you release the yellow imaging unit (the bottow row of units)
Just realease and pull it out a little way. Then switch the machine on with the door open. It won't start, but will ask you to shut the front door. Reseat the yellow imaging unit and shut the door. The machine should go in to a stabilization mode and then work.
However, if it comes back, I suspect a new yellow imaging unit will be required.
Jan 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Errorcode c-2555
Good morning,
Just had the same problem & it was low toner density on the yellow toner. We told to change the toner or shake the existing one & put it in again.
hope this helps.
Oct 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
No software
This can be found at vivitar.com.
Aug 04, 2008 | Cameras
Vivitar ViviCam 3740 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
