Question about Home
Hello once I've turned my stand alone bath taps off the water keeps leaking out of the shower part even when the switching device is push were it's supposed to be any ideas
    Novelist:
  • 88 Answers
You have a bad O ring, and need to replace the cartridge, you will need to shut the water off before attempting to change the cartridge, you can shut the main water supply off, or you can shut the water off behind the surround at the mixing valve, take the cartridge to your local hardware store to match it up. Please remember to shut the water off !!!!
Hope this helps.
Posted on Nov 17, 2013
3 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
SOURCE: no water coming out of shower in master bath
I had a similar problem. Turned out to be simple to fix. Unscrew the shower head to see if water flows. Mine had a piece of solder stuck in it.
Posted on Jan 18, 2009
My tub and shower are side by side. I can only get hot water in my shower if I turn the tub on first, why?
seen it in hotels etc
inbuilt scalding safety feature
there is a valve in the bath tap system
once the pressure is up to shower head
hot water
Oct 31, 2016 | Home
Bensham tap not switching shower flow to bath
If your Bensham tap not switching shower flow to bath then you should check the connection first and if still the problem get not solved then you should hire a professional to fix this problem.
Feb 04, 2013 | Home
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
My creda shower 8500dl won't shut off water keeps
Switch off the power at the main switchbox!
Unscrew the shower cover to reveal the main valve/switch assembly (green in my case)
On the green valve you can line up the bit that moves to select power settings and remove it
Undo the two screws holding the outer switch frame and lift it off
Undo the two screws holding the valve body in.
Remove the valve body, underneath you will find an ordinary tap washer - probably split
Replace the washer - I didnt have an exact match in my toolbox but drilled the middle out of a large tap washer to match
Reassemble..
Aug 10, 2011 | Home
Looking to replace my bath faucet and shower head. Have turned off the water supply in my basement but over an hour later I still have water dripping out of the tap. Wondering what the problem is and how...
Water pipes throughout yoru house need to be drained, this is assuming that the water is actually turned fully off. Also, turn off the hot water tank, as sometimes that keeps expanding and pushing water. Open faucets in the basement and on the top floor to facilitate draining.
May 02, 2011 | Home
Water fails to flow through shower head although the bath and sink taps work
unscrew the shower head counter clockwise. Most shower heads have a wire mesh screen built in. remove it and wash out with water. Before re installing I would turn water on to be sure your water is reaching the shower head. If not your problem is at the water valve
Apr 14, 2011 | Home
Hi i have installed a few bosch gas geysers at our lodge in mozambique.The problem is that the water gets hot when we turn the water on then the heat just shuts off and the water gets cold after a short...
The problem with all that type of water heater is that once the hot tap is turned on sufficient flow must be maintained through the water heater to keep the main gas burner alight. If the heat adjuster is turned up to high, then the person using the hot water will turn it down to a low rate which means the main burner will turn off and result in cold water. Try setting the heat control to the lowest setting that still gives hot enough water. If you have a thermometer adjust control for a temperature of around 50 to 55 degrees Celcius. You may have to fiddle with fine adjustments to get the temperature and flow rates to maintain a constant output of hot water. You may still have intermittent problems. If the heater only supplies baths or showers you could set the temperatuer even lower (45 to 50) to ensure that the hot tap is used more than the cold which will maintain flow and therefore heat.
Nov 22, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Fitting stand alone bath taps
These are normally connected with a chrome waist & overflow assembly that passes down into the floor where it connects into the plastic piping with the use of an 1.5" trap adapter.
All that can be seen on the finished product is the chrome parts.
May 03, 2010 | American Bath Cast Iron Slipper Wintess...
Water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Jun 14, 2009 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
Water flow out from the overflow tube
open the sunroof ,stand on the seat then you can still breath when your escort fills with water
Feb 19, 2009 | 1998 Ford Escort
Home Logo
47 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
