Question about Sharp AQUOS LC-32D44U 32 in. LCD TV
Not compatible with the signal - Sharp AQUOS LC-32D44U 32 in. LCD TV
What modem are compatible for n75 db dual band N router
Any modem should work; the modem is the device that provides a signal to and from the router. I have never run into any compatibility issues for a signal TX/RX device.
May 17, 2014 | Belkin N750 DB Wireless Dual Band N Router
Connect
Sometimes your phone isn't compatible with 3g networks. Try checking the model of the phone and whether or not it is actually 3G compatible. If your phone is 3G compatible, you might have to move around to get that signal.
Jun 29, 2013 | straighttalk.com
Samsung sgh-m200 has no network
No Network error only appear if your phone is not getting the service provider's signal. You need to check the status of your account from your mobile service provider by calling them. You can also check if the sim is properly inserted. You can also check the capability of using compatible sim card to your phone to isolate faulty sim card issues. Try to insert the sim card to another compatible phone as well. if sim card to another compatible phone works then there is a problem from your phone's end by getting a signal.
Dec 08, 2011 | Cell Phones
My astar wont work in europe
There are three major types of TV transmissions and they are not compatible unless the manufacturer lists them as such. Only a few sets are universally usable across the planet.You mentioned Europe but not where you and the set originated so not much help available beyond the above.If bought in the USA, it won't decode any signals originating in Europe.You may be able to find a converter that can receive signals there but supply a compatible video-audio signal but that is also questionable.
Oct 03, 2011 | Astar LTV-2701 27 in. HD-Ready LCD...
Screem wite
Telephones are made compatible with voice, text, video also internetworking compatible as manufacturers default feature functions. Ascertain, that the telephone provides beyond voice communications. For example, recently innovated telephones are internet compatible requiring establishing subscription from provider as subscriber agreements to capture signals. In a situation that telephone least is recognizable as internet compatible is verifiable from telecommunications structures. Several options become resolvable. First, telephones with networking features are enabled with signals as an agreement to resources sharing amongst several features. Second, telephones least without network features is resolvable by exchanging with network enabled phones especially being customer makes exchanging phones to attain network compatible telephones with an alternate agreement to resources.
Mar 05, 2011 | Nokia 6600
MINI-E89 i want to connect it to the internet and browse with it
Mar 04, 2011 | Nokia Lands Phones
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
WILL THIS TV ACCEPT THE NEW DIGITAL SIGNAL
Hello. All tv's accept the new signal. If you get your signal from satellite or cable, the box will make the signal compatible with your tv. IF you get your signal from an antenna, you may need a converter box, available from places like radio shack and staples.
Dec 23, 2009 | Televison & Video
Is my tv digital?
It is not a matter if your TV is compatible with a digital signal, it is the signal being offered to the TV.
Meaning, if you are using Cable TV, you are fine and need no further action because the digital signals are already converted by the Cable Box into either an analog TV (RF) signal, or a PBR (RGB or Comp.Video) signal which the TV understands via a separate input (external video input).
Feb 14, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Digital signal hookup and compatability
the tv will be hd through the dvi port you can purchase a converter at most shops the you plug the hd freview sat and it will work if the tv has freview built in then it will still work when the switch over happens
Jan 17, 2009 | Hitachi 46F510 46" Projection HDTV
Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
