Question about Foxconn 661FX7MI-RS (661FX7MIS) Motherboard
It will go to foxconn display only. Will not go to bios
The board will only show the display logo and it will not go to bios could you please tell me what i could do to get this board started thank
    Novelist:
  • 231 Answers
Hi, your problem sounds like faulty RAM to me. Try different Ram or change the Ram you have around and see if this fixes it for you.
Posted on Oct 08, 2007
SOURCE:
For change bios logo
you can go into cmos to do that.
Mar 19, 2014 | Foxconn Bios Chip:45cmx 45cmx-k 45gmx...
Hi, I have an Acer Aspire 5610z and, when I turned on the Acer Logo nor bios post shows up. The entire display remains dark. If i press F8 or scape, nothing happens and no bio sound but, power light comes...
Dear User,
Remove the battery and connect the adapter and check if display comes otherwise the issue seems to be with system board.
Regards,
Tech_Comp
Feb 23, 2011 | Acer Computers & Internet
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
Foxconn 648fx4mr-es boots up no display
u take M.B outside .then u install cpu , agp, ram , power supply ,finish u running . please u try.
Dec 11, 2009 | Computers & Internet
Startup fault
Software Error Or Corrupted windows File files
Jul 15, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Fan, HDD... everything is working but no display.
You have no display, and cant even get to the bios screen.
OK, does anything at all show on the monitor when starting?
Logo,etc?
If that is the case, look to your video card or monitor.
I cant tell you how many times I have seen pins that are bent or proken on the VGA cable. or even plugged in.
Please check these things and let me know what you find
Nov 18, 2007 | Intel Desktop Board D845WN Motherboard
Board will only show display
plz check wether the hdd and cdrom drives r connected properly. when a drive is not detected the system hangs, check the bus and the led connections and if possible u change the ram and check out
Oct 07, 2007 | Foxconn 661FX7MI-RS (661FX7MIS)...
Requared bios updated versin for foxconn 865gv chipset mother board
Hi, I run a foxconn mobo myself and yes its a great board. But dont go to the foxconn site looking for downloads. instead go to the VIA site they make the chips and you will get more sense there. If all else fails Foxconn do have a "Contact us " link on their home page. This will give you the company email address and you could request directions to the update site there, the only trouble is it could take weeks to get a response. Regards mistyman
Aug 20, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Foxconn 661FX7MI-RS (661FX7MIS) Motherboard Logo
107 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
WTF Chuck.....
WTF Chuck.....
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
