I've a problem. When i switch on the tv. It says no signal. I've thought of turning the satellite but it keeps saying no signal and the signal quality stays at 4%. How to do? Configuration: technosat.
Firstly the satellite dish antenna must be correctly aligned to satellite you want to receive.
technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
Posted on Nov 17, 2013
  • Steven Jeremy Watkins
    Steven Jeremy Watkins Mar 31, 2015
    Now I have nothing but a flashing red light on the receiver & trying to turn power on & off doesn't seem to help.
3 Suggested Answers
  • 8909 Answers
SOURCE: TECHNOSAT 5500 Super Smart USER MANUAL
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 19, 2010
spr1949
  • 1182 Answers
SOURCE: my dynex keeps saying no signal ..the satellite box is working fine but tv seesm to not recieve the signal
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Posted on Aug 27, 2012
Digital Lifestyles TV. No Signal
you need either a cable ,satellite, or antenna for an input to get any pictures from any place .
Aug 24, 2016 | Digital Lifestyle Televison & Video
Have no picture just keeps say no signal
Check the input jacks in the rear. Each should have a unique label. Pick one input that has cables connected to it. Note the input name. Follow the cables back to the device connected - DVD, BluRay, Cable / Satellite box, etc. Turn on the TV, and select the same input you noted above. Turn on the device connected to it (DVD, BluRay, Cable / Satellite box, etc.). If this fails, try again with a different device or connect the cable / satellite box to the antenna input and select ANT.
May 21, 2014 | Televison & Video
My panasonic viera has just stopped working. I can play a dvd but not watch tv, It says no signal. I have checked all leads and none are loose. It worked yesterday!! What is wrong with it? Please help
What is your TV source? Is it OTA, cable or satellite? Do you use a set top box or a direct coax cable connection? If you have OTA, what antenna do you use?
Try the following depending on your setup:
For all, check if a lightning/surge protector has taken a surge and needs to be replaced. These are placed in the coaxial line to divert a surge that could destroy your electronics. Also try replacing the cables. Check exposed cable for damage.
For OTA, first check that your antenna is oriented to point to the transmitters in your area. (Outside antennas will sometimes turn in the wind; indoor ones can be bumped.) Try a new coaxial cable. If the antenna has an amplifier (or you use a splitter with or without an amplifier), try connecting the cable directly without the device. I've had several amplifiers fail and turn into signal filters (blocking all of the signal).
For any system with a set top box, make sure that the box is on. For satellite, make sure that your dish hasn't moved out of alignment.
To check if it is the Viera TV tuner or the incoming signal, try another TV at the same connection. If you have cable and another TV gets no signal directly connected to your incoming connection, you may need the company to fix the incoming cable. (Underground cables can be damaged by rodents or neighbors who dig without checking for utilities.)
I hope this helps.
Dec 21, 2011 | Televison & Video
I accidently pushed something on the remote to my sony wega trinitron and now it says 'no signal' I don't know how to get the picture back
You probably switched the TV from analogue to digital mode or vice-versa.
There should be a small button on your remote control marked DTV or ATV. Try pressing this.
If you are using a separate cable/satellite/tuner box from a SCART cable, turn off the tv, and turn off the cable/satellite box. Then turn the TV back on, then the cable/satellite box back on. The TV should recognise there is an external input and you should be OK.
Oct 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
I have a dish network 522 reciever that I can watch two different things on two different tvs. It keeps saying acquiring satellite signal, but only on one tv. The other is working fine. If i unplug...
So you have two sat receivers? is that correct? If this is so, can you please explain in more detail, if either TV can get either channel, or is it one channel one TV? If you are using two receivers, then I suspect, either the connections need re-doing, the in-line amp, if any may be going/is faulty, the LNA, has slightly misaligned. usually it is signal quality that stops things... check all connections and power supplies and the like.
Feb 26, 2010 | Televison & Video
No signal
Try changing the order you turn on your TV and cable box, don't switch both together. The TV will likely skip the HDMI inputs if there is no signal there. Alternative you can change the TV's source after the cable box is on and that should allow it to not skip the HDMIs. You don't have HDMI to DVI adapter(s) in the line, do you? -Ken
Jul 30, 2009 | Televison & Video
Satellite won't pick up a signal
just keep moving the satellite dish untill its in a perfect position.
Dec 20, 2008 | RCA DIRECTV Satellite Remote Control
SATELLITE DISH
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
Electro Med Services...
