Question about Thetford Norcold RV Cooler/Freezer
Will not get cold can a person wire the theromister wires together
Can the theromister make the frigerator not work
    Top Expert:
  • Thetford Master
  • 9,487 Answers
Disconnect thermistor at board let run if gets cold replace if not bad board or cooling unit
Posted on Dec 16, 2017
Hood release wire doesn't let the hood on my 1995 Toyota turcel release it so it will open
The wire could be broken or the l?tch might be stuck. Try this takes two people one person pulls the release the other person lifts up on the hood must be done together. This worked for me.
If this works spray wd40 on hood latch
May 29, 2016 | Toyota Cars & Trucks
Wiring diagram for 1986 gmc sierra 2500?
Other than POSSIBLY some gauge sending units, it should be reasonably simple. You could most likely re-use the temperature sender and the oil pressure switch.
The alternator should plug in the same. The starter wires should hook up the same. The ignition, providing it's electronic/HEI (big distributor cap with built in ignition coil in the top) will simply hook up to the wire that formally sent power to the injector pump shut off solenoid on the 6.2.
You won't, or shouldn't have to use ANY of the glow plug or cold advance/high idle wiring. The cold advance wiring should have 2 connectors 'pig tailed' together that was on top, towards the front of the 6.2.
Hope this helps.
This is only my personal opinion, but unless there was some major mechanical problems with the 6.2, I would have left it in. I have an '85 GMC K2500 with the 6.2, 3.73 gears, and 'granny' 4 speed. It gets an average of 20 mpg and does everything I ask of it. Yes, it's not a super power house, (they weren't designed to be) but if I had a 350 gas engine I can guarantee I wouldn't be pulling the mpg's that I do with the 6.2. Plus I can burn WVO (waste vegetable oil) which is free.
Like I said, this is only my personal opinion.
Jun 21, 2015 | 1986 GMC K2500
Freezer and frigerator not getting cold
Good Afternoon friend, thank you for your post!
Based off my understanding your Frigidaire refrigerator is not getting cold. This could be a possible issue with your sealed system, control panel, or wiring harness. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not help correct your issue since it could be one of the underlying issues you may need to seek assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful to you. -Matt
May 28, 2015 | Frigidaire Refrigerators
Freezer and frigerator will not get cold
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Oct 04, 2011 | Amana ARS2464B Side by Side Refrigerator
I have a side by side Frigidaire gallery. it is not cooling at all freezer nor frigerator..The lights are on though!.
NOTE: This
Leo Ponder
Sep 10, 2011 | Frigidaire FRS3R5EMB Side by Side...
My ge refrigerator turns off on its on and when its shaken it turns back on?
NOTE: This
Leo Ponder
Aug 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Frige is not working motor runs for a minute then cutoff
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Whirlpool Refrigerators
Hdbc36id wont get cold
Leo Ponder
Aug 15, 2011 | Franklin Industries FBC360D Beverage...
The freezer works but no cold air in frigerator in side by side unit.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | Refrigerators
The frigerator and freezer are not getting cold enough.
It sounds as if your unit is low on freon.You will need to have a quailfied repair person to refill.
Jul 02, 2009 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
97 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
tom wright
tom wright
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
