Question about Indesit Washing Machines
Removing soap drawer on WIA 101 - Indesit Washing Machines
Remove soap drawer lg wm2101hw
the sponge is probably making it's way to the bottom of the machine as we speak. disconnect the power, and lean it back wards. the sponge should be on the ground there. otherwise pulling it out from the wall and removing the back panel should reveal it's location.
Nov 10, 2013 | LG WM2101HW 4.0 cu.ft. Washer
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaking out of soap dispenser?
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
I need to remove a drawer front for cleaning.
If this is a front loading washing machine..................Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
If helped, click.
Mar 02, 2013 | Refrigerators
Soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
May 09, 2010 | LG WM-2277HW Front Load Washer
Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Feb 20, 2010 | Washing Machines
Water filling the drawer but not going into the drum, maybe blocked with soap powder tried unblocking with a rod no joy....
Yes there is a blockage in the drawer.Try removing the lid after unplugging the power,and you may be able to reach down the front and squeeze the dispenser hose a few times may break up the soap.
Adrian
Jul 06, 2009 | Hoover PE235 Front Load Washer
WIA 111
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 17, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
