Question about Cutter Tools
Do I need a lot of tools to cut tiles? - Cutter Tools
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 15 Answers
You don't really need too many tools to cut tiles, mainly just a tile cutter, tile nipper, sharpening stone and pencil.
Posted on Nov 17, 2013
12 x 12 marble tile I have put that up twice don't know why it is not appearing
60 if there are no cuts.
You usually add about 10% for waste. So 66 tiles should do it.
Jun 11, 2015 | Instant Mosaic Metal Tile: 12 in. x 12 in....
How to fix laminate floor tiles gaps?
First, you need to get to one edge on the narrow side. (Where the slats run toward)
Second, you need a mallet and a hook tool.
Essentially, you need to put force on the edge to push the slats/planks together.
The mallet is used to put a lot of force on the slats to push them together.
The hook tool is inserted at the end of the row of tiles/slats/panels. The mallet is then used on the other part of the tool, so every hits force is transferred to the tile.
The slat/tile then will slightly shift toward the next one. Eventually this will put them together. Probably 4 to 8 mallet strikes should do on each row.
If this is an already installed floor, you may need to take the floor trim board off to get access to the edge of the tiles.
Jan 25, 2015 | Building Materials
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
Cuts are bowed
I heard that the rod that it rides on, may be bent. This is the rod, that you normally adjust, to get your straight cut, parallel to the blade. One mans solution was to turn the rods, so the bend of the rod, was vertical, rather than horizontal. You may want to look into ordering new , hopefully straight rods, from QEP too.
Jul 13, 2013 | Qep Tile Tools 83200 24inch Bridge Saw
Was going to buy " the beast" but have seen a lot
"In my opinion" I would stay away from the Ridgid tile saw. We had one come into our shop for repair of a burned out motor and could not get parts for it. The saw, at that time, wasn't made by Ridgid, it only carried the Ridgid name. I'm not familiar with the Dewalt tile saw enough to give you an opinion on it. If I were in the market for a tile saw, I'd get one by MK Diamond, they specialize in tile, stone, etc. cutting and make the best tile cutters I've used and worked on. They're priced towards the high end but are of contractor or industrial quality so will last a long time. If they do need repairs they're easy to get parts for that are fairly priced.
Jan 31, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
How to lower the blade it's not cutting all the way thru..stand. 12 inch tile..help please
a temp fix,put a thin rubber mat under your tile.my bridge saw does plunge cuts & has a knob on side of cutting head, your blade must have been changed somewhere even if changed with the same size blade some vary in overall size,good luck
Nov 05, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
Tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Cutter Tools Logo
1,678 people viewed this question
Top Cutter Tools Experts
Joe Garcia
Joe Garcia
Are you a Cutter Tool Expert? Answer questions, earn points and help others
