Question about Microsoft Xbox 360 Console
XBOX 360 ERROR E67
I was playing my game and it froze now when i start my game it comes on with chiness words an says E67 at the bottem
  • 2 more comments
  • xjsv12jag Nov 06, 2007
    I bought the xbox 360 two months ago. I've played 3 different games and all have froze at different time intervals. Is this due to overheating? And, if so will an external fan stop this problem. Also, if this is the case then why didn't Microsoft but in a bigger cooling fan? Shouldn't they sell products that work?
  • toddler Dec 22, 2007
    Was given an X-box 360 for gift I got the E-67 error when I turned it on for the first time. If you remove the hard drive from the top of the unit and turn the power on it will play and read dvd and cd audio, but will not play games witout the hard drive connected.
    Spent 1/2 hour on the phone with x-box support, seems to be a hard drive dud, I will need to send the console in and wait.
  • for ballin May 11, 2008
    dammit man this **** is ballin i just got gta 4 nigga this **** is of the hizzie my fizle you just run around popin caps man this **** is so raw i am so fly yeaaaa boii
  • amelita_b Dec 31, 2008
    My X-Box 360 was not even a year old when it error E67 came on what did I do to fix this problem.
Ive had mine for a year and a half mine did that twice . i found that my hardrive was loose so make sure its connected all the way and if it is just take it out then put it back in
Posted on Apr 19, 2009
    New Friend:
Red Light of death one.
Posted on Nov 18, 2010
WTF? Change the language did that actually worK?
Posted on Oct 06, 2008
Try to start the xbox without hdd then restart it again with hdd
Posted on Nov 05, 2007
Simply change the language back
Posted on Oct 08, 2007
2 Suggested Answers
6ya staff
SOURCE:
Al Toledo
  • 223 Answers
SOURCE: MY XBOX 360 KEEP SAYIN E 67
E67:
Hard Drive Error - Hard drive timed out during reset: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
Al
Posted on Jul 30, 2010
Words with Friends
When I am playing Words with Friends my friend plays a word and the caption off to the side says he has played but it takes a while to appear, yet others I play it is instant
how come the delay
Jan 13, 2014 | Facebook Apps
My 360 will let me play a little bit of a game at a time. after playing maybe 5 or ten min or so it will freeze up. the last two times that it froze up it asked me two clean the disc, or contact xbox3660...
You specify the xbox 360 do you know what year model you have? If it as earlier model then likely you are running into system instability with many reasons for the error being possible.
Does the error only appear with one particular title or across your game library?
If it is just one game then attempt to install the game onto your hard drive and play the game after that. To install the game onto your hard drive you will need to do the following:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Jul 18, 2011 | Microsoft Xbox 360 Console
When playing COD Black Ops yesterday my system froze. The screen seems to have a lot of red pixels. I reset it 4 or 5 times and the game played for 5-10 mins before freezing again. This evening I can't...
i got the same problem only with my ps3 it froze while i was playing black ops online so i turned off the power n after i restarted my ps3 he could not read any game discs anymore, im now busy with reformatting my ps3 i dont know about the xbox but maybe u also have the abbility to reformat ur system if so do it but put ur saved files on a usb stick or on somthing els cus u will loose everything but ur system gets a clean start and it checks for system errors wich come by shutting off the power wile it was not ment to and fixes them
Jan 31, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
I put my nintendogs: chihuahua and friends into the action replay DSi and entered the codes: maximum walk distance max points disc competition hold R+L while saving for jack russell terrier and now...
i dont know whats wrong with it but mines like that too. i tryed truning on and off and keep on trying.mine wasnt your game it was pokemon platium. i had put a whole bunch of codes in just then. i got mad so right when it froze i truned it off and tryd it without my action replay it still worked without the action replay but when i tryed with action replay again it froze. im still trying to find a cure but i think we got bad apple chaets(in other words vires cheats).i dont know if thats the case but with your action replay try takeing off one of your codes for that game(that didnt come with the action replay)and try starting it up. if it does email me at [email protected] .also if any of you find out what it is and/or a salotion to this tell me.
Jan 10, 2011 | Datel Action Replay for Nintendo DS
My xbox 360 has one red ring and i dont know if i need a new on or can i fix it
Solution
An error code will appear on the screen as well, which states what component the 360 thinks is faulty.
E67, E68, E79
These could all have something to do with the hard-drive. Try taking the hard-drive out from the 360 and playing without it. If the error message disappears, then your hard-drive is faulty, and you will need to get a replacement. If the error message still appears, then something else is wrong with your 360, and you will need to send in the 360 for repair.
Any other error message is not user-serviceable. You will need to return your console for repair.
Dec 22, 2010 | Microsoft Xbox 360 Console
E67:
Al
Jul 30, 2010 | Microsoft Xbox 360 Console
I have an xbox 360. my mom dropped the dam thing. it comes on but it goes to a black screen telling me to contact xbox. some kind of ''E'' something error. is there anything i can do myself before i...
if its E67 E68 or E74 it could be your hard drive isnt seated right after the fall, take out your hard drive and turn on the xbox, really we need to know what E number it was to help you more.
Jan 23, 2010 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,666 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
