Question about Dell Xps 15 Laptop Computer (Intel CORE I5 500GB/6GB) (dndoge1) PC Notebook
Error code after running diagonistics
Recently my laptop started crashing followed by a blue screen with msg dumping physical memory....I have run the diagnostics, Error code 2000-0333 & 2000-0146 were detected. Can anyone explain in detail about the problems. Does this problem need to addressed immediately.
    Top Expert:
  • Dell Master
  • 25,331 Answers
If you run Advanced System Care that will repair your errors, if repairable.
Looks like a fatal error though. Back up your data,NOW!
Posted on Nov 17, 2013
Testimonial: "Well I am using tune up utilities 2014, nothing has changed."
4 Suggested Answers
  • 268 Answers
SOURCE: When I started my DELL Inspiron 1525 running Win 7
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Posted on Oct 18, 2011
  • 115 Answers
SOURCE: I have a dell inspiron 1520, today when I was
the problem is with your memory card as one memory module is not functioning which is in DIMM 1. you need to replace it.
because which playing music file as due to damage memory it takes time for buffering. and that is why you hear choppy sound. you can also run a test on memory. Restart the sys. and press F12 on blue Dell Logo. and goto BOOT TO UTILITY PARTITION and run a test on memory it will hardley take 5 mins. and it will give you the result.
Posted on Nov 04, 2009
  • 401 Answers
SOURCE: Dell Inspiron E1705 Error code 5300:0119
CHANGE MEMORY
Posted on Mar 28, 2010
Blue screen appears & keep restarting
It is possible that the malware is to blame, in which case a computer technician will need to sort it out.
I think it may be a bad memory module or loose memory module connection.
Take care!
damnor01
Apr 28, 2012 | Acer Extensa Computers & Internet
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
don
Feb 23, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
Physical memory dump
Hmm... Well a Bluescreen is when your computer crashes, and (as you have found out) preforms a physical memory dump. This can be caused by multiple things. Such as bad drivers, PFN(page frame number) or problems with your memory. When a bluescreen event occurs, the is a technical information which has an error code that can be used to help find the problem. In order to fix this problem, you may have to remove any software, or hardware that you have recently installed. To uninstall software, you may need to boot in safe mode, which is where your computer starts up using the minimal amount of drivers needed, in order to try to prevent the computer from crashing.
Here are some useful websites (sorry, my hyperlink icon isn't working):
  • www.datarecovery.com.sg/data_recovery/hard_disk_symptons_blue_screen.htm
  • www.maximumpc.com/article/features/blue_screen_survival_guide
Feb 27, 2010 | Dell Dimension 8400 PC Desktop
My toshiba satellite M55-S135 is showing a blue screen with "physical memory dump complete" & to contact tech support. Basically, wanted to ask if my laptop is crashed...
Hi:
Crashed is a generic term, and the physical memory dump error is a windows based error that could be a bad memory stick, or a corruption in windows. If you have 2 sticks of memory in your laptop, a cheap and easy way to troubleshoot this would be to remove one stick, then the other,to see if one stick removed stops the crash. If it does, then you have solved the problem, and if it doesnt' then you have a corrupt software issue.
Hope you get a cheap fix!
Jan 18, 2010 | Toshiba Satellite M55-S135 Notebook
Blue screen error message (Crash Dump)
kernell has over run the memory....
some corrupt registries may also cause this issue...
u can try to run a registry cleaner (Tuneup Utilitis or Registry defrag etc can do the job...search in google)
else
do a clean install of OS after data backup
Dec 14, 2009 | Computers & Internet
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
My computer has a virus I can't remove
Try and boot into windows safe mode by pressing the F8 key before windows loads and then try running the browser and check if it crashes. Perform the same process by scanning with an anti virus and see what happens. You might have two problems, either the RAM the actual memory is bust or something in the OS has gone really wrong and got the OS unstable. Try the safe mode test to confirm.
Feb 24, 2009 | Fujitsu LifeBook T4215 (FPCM10951) PC...
Blue screen
hi daget200;
can you post the exact error message? its located at the top few lines so that we will know whats causing it. have you inserted a new hardware recently? when does the error occur? intermittent? does it happen when you are playing games or something? pls expound. thanks
Jun 07, 2008 | Computers & Internet
Dell Xps 15 Laptop Computer (Intel CORE I5 500GB/6GB) (dndoge1) PC Notebook Logo
175 people viewed this question
Alun Cox
