Question about Breville Kitchen Appliances - Others
Breville kettle not making good electrical contact with base
When filled with water and switched on, kettle will switch off before boiled and only occasionally will continue to boil when switched on again.Haven't been able to get into base to check as no screws. Regards, Tony
5 Suggested Answers
SOURCE: light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Posted on Feb 21, 2009
  • 4 Answers
SOURCE: Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Posted on May 04, 2009
homemender
  • 158 Answers
SOURCE: When filled with water & put on to boil it
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Posted on Dec 23, 2010
brenda_scofi
SOURCE: Bodum kettle boils too long before automatic cut off.
Mine does the same and now the switch doesn't work at all. Bodum is replacing the whole kettle.
Posted on Nov 02, 2012
What are good features to look for in an electric kettle?
One of the best feature of electric kettle is it should be cordless. One of the most advantageous benefits experienced by those choosing to switch from the traditional methods of boiling water to the more convenient cordless electric kettle comes in the form of optimized time savings, cutting the time it normally takes to boil water by as much as seventy five percent. So for the cordless electric kettle water level indicator is essential. It must be long lasting and more durable. You can get more information about it from the coolkettles.co.uk. so go with this my provided link.
Nov 24, 2012 | Office Equipment & Supplies
Have a problem with a Breville Classique kettle,model number jk91. It does not switch off automatically. Any suggestions please? regards Sandra Smith e-mail davidforrest@hotmail.com
Every kettle has a thermostat/thermometer that trips the switch to off when the water reaches boiling point. The solution is not usually something you can do yourself. Your best bet is to consult the manufacturer for a repair/replacement (if under warranty). I recommend that you contact the retailer first as most retailers have an agreement with the maunufacturer to replace most small kitchen items if it's still under warranty and develops a fault.
Jul 06, 2011 | Breville Kitchen Appliances - Others
How do you clean a Breville JK73 kettle. I have lost the instructios.
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
When filled with water & put on to boil it start's boiling as normal then after 10 or 20 secs.the lights inside flicker off and the kettle ceases to boil then the lights flicker back on and boiling...
Jun 28, 2010 | Russell Hobbs 14339 Cordless Electric...
Our kettle has started making a crackling noise when turned on now; thought it does boil the water, and there is no odd smell from it.
Our kettle start making the same noises and now no lights come on. i can spin it around the base and sometime it connects and work. i think it's an electrical issue of the base. i wonder if anybody knows if it's possible buy just that part, i would hate to buy new kettle just because of bad connection.
Jan 24, 2010 | Breville SK500XL Stainless Steel Cordless...
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
Switch has stopped working, kettle will not heat water
Hi Bruce or anyone else that has this problem.
I had this problem too and after pulling the base off I found that the switch was ok but the problem lay with the two bi-metallic thermal overload switches that are connected to the heating element. I managed to reset them both and now the kettle works fine. This can become an issue if you have accidently boiled the kettle dry once in it's life. Best of luck.
Apr 22, 2009 | Breville SK500-XL Stainless Steel Cordless...
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Light switch on Breville SK500-XL Kettle
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Kitchen Appliances - Others Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
