Question about Bosch Classixx WFL 2066 Front Load Washer
How to reset bosch wfl 2463 GB/12
Was not spinning so put new carbon brush after that washing machine lost the power
gittos73
  • 244 Answers
SOURCE: remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
Posted on Feb 25, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 106 Answers
SOURCE: Bosch WFL 1660 Front end
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Posted on Feb 28, 2009
barkencoa
  • 3463 Answers
SOURCE: how can i remove the motor in order to cahnge the
The best way to do it is to disconnect the washer from the water supply and electric socket.
Lay the washer on it's side, and remove the rear cover and drive belt.
Undo the 2 screws that secure the motor in place, unplug the motor lead, and earth lead.
Prize the motor away from drum.
Change the brushes.
Please rate my solution.
Thanks.
Posted on Nov 21, 2009
Testimonial: "managed to change the brushes. wasnt able to remove the motor? didnt want to damage machine. thanks for your help. Dan"
tony2155
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
Bosch wfl 1880
spin switch will fix this
Dec 16, 2013 | Washing Machines
Machine is not spinning
check the carbon brushes in the motor or the belt.if its not these then it may be a timer fault see if you have power to the motor
Jun 02, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Slow spin
Check the carbon brushes on the motor for wear.
Apr 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I have replaced the carbon brushes on my WFC 20062GB /12 Bosch washing machine, but the motor will still not operate any suggestions. The commutator is clean and not burnt Thanks
Make sure the brushes are fitted the correct way, as they are tapered, and it is important they are the correct way around.
Check all connections to the motor, if it still will not work, then it is either the motor or the control board that it is likely to be faulty.
Mar 21, 2010 | Bosch Classixx WFL 2462 Front Load Washer
Want to replace motor brushes...any tips on this
I need to also, so please post what you learn. I found several examples for other WMs on YouTube (search brushes carbon washing machine) Note, I was able to get my Bosch Axxis WFL 2060 spin working again with the following quick carbon dust cleaning trick:
1) Unplug WM and tip up to a 45 degree angle and then safely stabilize so you can safely access motor from bottom. No need to take off back or disconnect motor.
2) Using a small tool like a 1/4 allen wrench or medium screwdriver start tapping repeatedly (for 2 mins) on the brush holders, and back metal clips that connect to the brushes, your just moving the dust around really.
3) Next using an alcohol damp cloth clean the motor commutator - on this motor it is easily exposed on one of the sides 90 degrees away from, and in line with brush holders. Hold cloth on commutator and turn motor, this will also make it clear if commutator is damaged. You cloth should be pretty dirt after 2-3 rotations.
Repeat 2 and 3 above a few more times cleaning up all the carbon dust off the commutator and around the brushes.
After that tip down and test again. A more thorough cleaning could be done by removing brushes and cleaning em - but this will buy you a few weeks/months of operation.
Sep 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Wont spin, and arcs.
2 bruhes in motor
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
62 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
