Question about Jamo Audio Players & Recorders
Scheeme jamo c607 crossover - Jamo Audio Players & Recorders
Replacement remote for Jamo 360 soundbar
Amazon.com: Replacement Remote Control for JAMO TORSTEN 360 ...
https://www.amazon.com/Replacement-Remote-Control-JAMO.../dp/B01E67NI6U
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. *This is NOT an original JAMO remote ...
Replacement Remote Control for JAMO TORSTEN 360 ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls US$38.81 - ‎In stock
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. This is NOT an original JAMO remote ...
jamo replacement remote ' AVForums
https://www.avforums.com > ... > Home Cinema Speakers Oct 5, 2014 - Hello, I have jamo p102 speakers. Unfortunately the remote is broken which means I can't control the speakers at all now. It can't be fixed. Is it... Replacement remote for Jamo 360 soundbar Google Search
Feb 01, 2017 | Jamo Audio Players & Recorders
Hi,,is there a Jamo service center here in Davao City? My speaker need a repair.
Hello i am from outside the States but i know any KLIPSCH service center is maybe the place for JAMO or they know for sure where you should be in your Country.
Jamo About Jamo About
Sep 23, 2015 | Jamo Audio Players & Recorders
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
I have a pair of jamo R909 speakers that need crossover / board replacement--- any thoughts or suggested repair options? The company has been horrific. Love the speakers, but the company doesn't s
Hi Katrina,
Yes parts are available for your R909 speakers.
firstly I am surprised that you have managed to blow both tweeters and crossovers.....there must of been some serious distortion/amplifier clipping involved there???
So a couple of things.
Can you actually see damage to the crossover boards? If so what components have been damaged? i.e board loactions and parts.
The crossover is available but they are not cheap. $1560 each (AUS)
So it would be preferable and much cheaper to repair them at board level.
Tweeters are also available.. $745.00 each (AUS)
Regards John
jb@qualifi.com.au
May 15, 2012 | Audio Players & Recorders
Hi! I have purchased a JAMO S608 HCS 3 and a SUB 650 using an OKYO TX-SR508 Receiver. I can't set it up correctly. When I played music I've heard a lot of bass, I think there are some high...
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
Sep 08, 2011 | Jamo SUB-650 Subwoofer
Cannot get jamo 250 subwoofer to work via marantz SR4002. Have power but no sound. Also are trying to connect PS3 via HDMI which is no probs however, cannot connect via optical audio
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Nov 02, 2009 | Marantz SR4002
Jamo Sub300. No power. No lights
Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
Charles
Jan 05, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
I have purchased brand new Jamo speakers A 320. Front and surround measure with ohm meter open circuit. Centre speaker Measure impedance 6 ohms. Is this a normal,i have also checked another set of the...
Most better low frequency speakers (woofers) measure about 6 ohms because the addition of crossover will bring the impedance up to 8 ohms. Even without the crossover, 6 ohms will not harm the amp or speakers
Aug 15, 2008 | Audio Players & Recorders
Volume
It's the receiver, same prob here. The level of bass through the sub is negligible too. So my guess is it's either related to the crossover or the passthrough in general.
Looking for a missetting or workaround.
Mar 04, 2008 | Onkyo TX-SR605 Receiver
140 people viewed this question
Top Jamo Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
