Question about Sub-Zero 700 Refrigerator Freezer Drawer-700 Sub-Zero
Water is leaking out from the fridge floor onto the ground.
The gutter / collection tray at the back is full. I don't see where it goes. There is no hose. The entire backwall is covered with a metal plate. Does this need to be removed? How to fix? I see no ice or any buildup in the freezer.
  • 44 Answers
The drain pan in the back evaporates from the heat of the compressor. The freezer drain drains into this pan. If there is water under the bins it sounds like the drain is partially clogged and over flowing into the refrig section. But I need more info, like model , brand.
Posted on Nov 19, 2013
3 Suggested Answers
SOURCE: Our model 532 keeps over filling the ice maker
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Posted on Aug 11, 2009
ryanmalin
  • 40 Answers
SOURCE: cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Posted on Oct 10, 2009
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
My FRE 196A fridge won't drain.. is there a stopper in the drain. This has been the case since I bought it a year ago. When I pull out the veg drawer water under the drawer spills onto the floor and also...
To an evaporation tray. Some have coils to heat the water to evaporate it some have nothing some trays are incorporated into the compressor as it's base.
Oct 20, 2013 | Frigidaire Freezers
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My hotpoint future fza34 is leaking from underneath
you need to get to the back of fridge and ul notice a tray full of water ontop of the compressor. remove tray and empty water out. when replacing v important to make sure it is sitting level on compressor again.
there is also an underlaying prob here, maybe alot of condensation on shelves also??
ensure doors are closing properly and saels are in good shape, also avoid putting warm food in fridge and make sure liquids are covered. this should stop tray filling with water and leaking
Sep 23, 2010 | Hotpoint Freezers
I have a Woods refrigerator that is all fridge, no freezer compartment. Model # RFA17NAC. s/n 07605297JG. It is leaking water on the inside of the fridge and collects on the fridge floor. No manual came...
Hi Linda. We have the identical model of Woods all-fridge and
experienced this problem several times over the course of several
months. Hopefully this is still timely.
The short answer is that the clear flexible-plastic drain tube that runs
from the inside rear of the fridge down to the catch tray (underneath
the cabinet, next to the floor, behind the kick-plate) is sufficiently
plugged (with some kind of gunk, probably from a spill inside the
fridge) to cause a back-up. I suppose the inner diameter of the tube is
maybe 3/16" so it can easily get clogged. Consequently, the water runs
down the inside back of the fridge & eventually ends up in the
depressions below the crispers. In our case, after those depressions
filled (and I hadn\'t noticed), the water would run out onto the floor.
Initially, I used a fine wire to poke some of the gunk out of the tube
but I didn\'t get it all out. Just enuff to let some of the water get
thru, but the tube would plug up again. After a few repeats of the
problem, separated by a month or 2 each time, I decided a more "drastic"
tube cleaning was required.
I suppose a good strong compressed air blast might clear the tube
completely, but I didn\'t have that available so I had to use a
semi-flexible wire & sorta gunk out the tube. It\'s been about 1.5
yrs. since that more thorough tube cleaning & the problem hasn\'t
come back, so I think the tube got plugged from a spill in the fridge
(which thankfully hasn\'t re-occurred... yet).
BTW, I don\'t have the manual either, but the lower part of the tubing is
accessible from behind the fridge. I didn\'t pull it completely out
(which might have disconnected it from its fitting), I simply reamed it
out while it was in-place.
Hope this has been of some help to you.
Norm.
Aug 26, 2010 | Woods Upright Freezer MU07W
Water leaking onto the floor from freezer drain...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. .
Sep 20, 2009 | Freezers
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Ice Maker in door of freezer-ref combo.
The ice maker has a float or full detection device that shuts the water off when trays are full. If you are sure this is where the water is coming from, then that's it.
Dec 27, 2007 | Freezers
Sub-Zero 700 Refrigerator Freezer Drawer-700 Sub-Zero Logo
146 people viewed this question
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
AJMAL KHAN
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
