Question about Bernina Artista 180
How do I take the head cover off a bernina 1008
I need to oil inside the 1008 but need to take the head cover off. How do I do this?
    Champion:
  • 241 Answers
These have a spring catch that holds the top down. I use a blunted polished tool that I gently pry it open with.
Posted on Nov 18, 2013
4 Suggested Answers
  • 19 Answers
SOURCE: Bernina 930 where to put oil
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops.
Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
  • 30 Answers
SOURCE: How do you thread a bernina 1008?
I hope I can explain this in an understandable way!
1. Pull the end of the thread from the spool to the left and "click" it into the little metal guide (on the top of the machine) that is at the back of the long **** in the top. It's easiest to do this by holding the thread tight between your two hands, placing it behind the guide, and pulling forward until it clicks in.
2. for the remaining steps, let the thrread slide between the fingers of your right hand, keeping a little tension on it, as you thread the machine with your left hand.
3. Bring the thread end forward, laying the thread into the ****, and continue downward, along the right side of the vertical silver bar/hook thingy.
4. Bring the thread under that bar from right to left, and go back up towards the top of the wide **** in the front of the machine. As you pull up, the thread will click into the lower bar/hook thingy.
5. Lay the thread along the right side of the wide ****, go over the top of the needle bar (the part that goes up and down in the ****) and bring it down the left side. It will click into the needle bar.
6. Bring the thread back down towards the presser foot. Right in front of the screw that holds the foot on, there is a hook that opens on the left side. Slide the thread behind this hook, and then thread the needle from front to back.
7. Hold onto the end of the thread and run the needle down and back up once. Pull on the thread, and it will pull up a loop of the bobbin thread. Stick the tip of your scissors or seam ripper into the loop and pull the end of the bobbin thread out.
8. Slide your top thread through the slot in the presser foot so it comes out from underneath the foot, and you're ready to go! (Be sure and hold onto both threads for the first few stitches when you start a seam, to keep if from jamming up inside.)
Let me know if you need any clarification.
Posted on Jun 21, 2009
  • 166 Answers
SOURCE: How do you oil a bernina 1008??
Probably the most important is the inside of the hook ring. Remove the bobbin case and open the hook retainer by pressing the catch on the left-hand-side. The hook can then be removed by just gripping the shaft on which the bobbin was mounted and removing the complete hook. NEVER OIL BEFORE CLEANING. This is the single biggest problem I come across - continually oiling any kind of machine without first removing the old, contaminated lubricant will attract grime. So ... get yourself a few cotton buds and carefully clean around the inside of the hook ring (the circular aperture where the hook was), paying particular attention to the small groove running round the outside. Rotate the handwheel to bring the hook driver round halfway to allow the whole hook ring to be cleaned. Use the opportunity to remove any clogged lint and grime that may have built-up on the underside of the stitch table. WHen you're satisfied it's all clean, then run a very light bead of oil around the groove in the hook ring, turn the hand-wheel fully to bringthe hook driver back to the left-hand-side and oil the other side of the hook ring. Before replacing the hook, take a good look at the groove that runs around the back side of the hook near the edge and thoroughly clean that too, before smearing a drop of oil around that edge with a finger. Replace the hook, making sure its properly seated in the hook ring and click the black plastic cover back into place before replacing the bobbin case. Your machine should now sound a great deal quieter, if you haven't done this for a while !! Good Luck !
Posted on Feb 17, 2010
On my bernina 1008 the selection lever is all the way up but I want it on the straight stitch but won't move.
Are you able to remove the top cover of your 1008? The 930 has a "lid" that can be removed to access the internal mechanism. Am suspecting that perhaps the selector has seized from old oil solidifying. If able to open machine, apply 1-2 drops of liquid Tri-Flow Synthetic Lube to every place where metal rubs against metal. Do NOT oil belt or nylon gears! Be sure to move the selector dials and levers and oil those moving parts too. To help speed things up, direct hot air from a handheld hairdryer into the internal mechanics.
Dec 27, 2016 | Bernina 1008
The wheel release to wind my bobbin on a 1008 will not move. What can I do?
It may be freed up with brute force and awkwardness. If you don't have a gorilla living with you try using a rubber glove to get a better grip on the knurled knob. If that does not work you can escalate to a pair of large pliers and protect the knob by using the glove. If you still can;t get it become angry so you have some adrenaline flowing then attack it with a pipe wrench.
Nov 17, 2013 | Bernina Artista 180
Bernina 1008 needle is hitting something inside and wont go all the way down
Sounds like the machine has gone out of time, it will need retiming
Aug 12, 2011 | Bernina 1008
Copy ready diagram of Bernina 1008
Not sure which diagram or scematic you want but feel free to contact me at callnrick@yahoo.com and I will reply with your need.
Jul 08, 2010 | Bernina 1008
My 1008 bernina sounds like it is straining to
Your machine needs to be serviced. Take it to an authorized Bernina service person.
Feb 17, 2010 | Bernina 1008
Hi, do you know where on a Bernina 1008 I can undo the top cover to clean the inside and get a ball thread out? I have worked out out to clean the bobbin area now I would like to clean the top...
Open the front door and, looking at the insides with the door hinge on the left, up inside, slightly to the left is a small shiny knob. If you press the knob, it releases a catch in the middle of the top arm and the whole cover will just come off. Replacing is just a question of pressing it back in place and the spring-loaded pin will retain the cover in place. There are no retaining screws.
Jan 11, 2010 | Bernina 1008
Nov 01, 2009 | Bernina 1008
Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Jan 26, 2009 | Bernina 1008
Sewing Machines Logo
78 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
