Question about Canon PIXMA iP1600 Printer
PixmaiP 6600D flashing lights after renewing inks Error 6502 Tried unplugging for 10 mins and re connecting
  • 4,345 Answers
Hi there
Solution:
1. Unplug the printer.
2. Remove the faulty Cartridge
3. Plug in the printer and press and hold power button
4. Keep it held down. Press Resume twice, and this should reset the fault.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
SOURCE:
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have cannon IP3680, but from today it's making problem (Service error 6502), would u please tell me a easy way to solve the problem...
The error 6502 is an "Ink tank position sensor error". It may be that the sensor is dirty and needs cleaning. Make sure you haven't got any bright lights shining into the printer.
Mar 01, 2011 | Canon Office Equipment & Supplies
Changed ink cartridge and now have error 6502 - have no clue what that means, but it won't print - yellow and green light alternate flashing
Error Code 6502 appears generally after changing a cartridge.
Solution:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 12, 2011 | Canon PIXMA iP3500 Printer
I have a Canon MP510 printer and have changed the print cartridges many times for refills but am now always getting error 6502. I've tried turning it on and off, unplugging it, holding down power button...
hi,
you mentioned that you turn off and on these is on of the solution of your problem
but in your case it doesn't work
error 6502 arise when ink tanks not snapped properly
follow the steps below
  1. Confirm that the printer is powered on and pull open the paper output tray .
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place.
note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
5.Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
1 -tank installed properly
2-not installed properly
6. check the status of each ink tank according to the way its lamp flashes.
  • - On: The printer is ready to print.
  • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • - Off: An error has occurred and the printer is not ready to print.
  1. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
  2. regards,
  3. cseian
Dec 16, 2010 | Canon PIXMA MP600 all-In-One InkJet...
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6502
That error says it's a ink tank position error, make sure there are no paper scraps in the paper path, and you might clean the encoder strip with a q-tip and water. Make sure the carriage can move freely from one side to the other.
Aug 09, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MP500 - "Error Code 6502"
Try holding the stop/reset button down for 10 seconds to see if the error clears. If it does not repost your error message to the forum.
Jan 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error 6502
1. With the printer unplugged, remove the ink cart to the right.
2. Plug in the printer, Press the POWER button, Do not release the POWER button, and then press the RESUME button twice in succession. Now release the POWER button, press the RESUME button 4 times.
3,The beeper may sound once, Then With the printer unplugged, after that reset the printer electronics ,open the printer and this process is finished.
May 31, 2008 | Canon MX700 Office All-In-One InkJet...
Error code 6502
1-- With the printer unplugged, remove the ink cart to the right ,
2--Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3--The beeper may sound once ,Then Unplug the printer ,then power back up and reset the printer electronics ,open the printer and this process is finished. I believe this should take care of your issue, it's basically a cold reset for the printer, Give it a shot...
May 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error code 6502 on MP510
why error 6502..........?????
Help me pls.........!!!!!!!!!!!
Feb 26, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
48 people viewed this question
Clive
Clive
old marine
old marine
Ekse
