Question about Arris DCT700 DTV Receiver
Getting vcr recording in progress on screen - Arris DCT700 DTV Receiver
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
I have a scientific atlanta explorer 8300hd dvr that I want to offload the recordings to either an external hard drive or a pc or laptop''
The 8300DVR has a feature built in for outputting redcordings to a VCR. To output to a PC you will need a TVTuner card with RCA inputs. Pinnacle offers several products including a Hard Drive backup. You will follow these instructions below, the VCR will be your computer.
Copy a Recording to a VCR Tape
1. Connect the VCR to the OUT 2 connection on the back of the Explorer DVR.
See page 12 for more information.
2. Make sure that a tape is in your VCR and that the VCR is set to record.
3. Press List . The Recorded List
screen appears.
4. Press Move Up or Move Down
to highlight the recording you want
to copy to the VCR. Make sure to select
a program that is not currently being
recorded.
5. Press Select . The Recorded
Program Options screen appears.
6. Press Move Up to highlight “Copy
to VCR.”
7. Press Select . The Copy to VCR
screen appears.
8. Make sure your VCR is properly connected
to your DVR outputs, and press
Record on your VCR.
9. Press Start copy A . The recording
begins copying to VCR tape. The
Recorded List displays the VCR symbol
for the recording that is copying to
VCR.
Note: You can watch the copying in
progress through the PIP.
Mar 31, 2009 | Televison & Video
I am stucking with system Menu on progressive mode on Sony RDR-VX530
First of all, confirm connecting cables are correct n OK.
2nd, please confirm VCR is giving output signal or not.
Jul 20, 2008 | Sony RDR-VX530 DVD Recorder/VCR
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Progressive Scan
Please go to the following link for an exact definition and how it is applicable to your situation. Please read all 3 pages of information!!!!! The short of it is, is that your TV may not be set up for progressive scan. Try turning off progressive scan on your DVD player's menu and see if this works.
http://hometheater.about.com/od/beforeyoubuy/a/progressivescan.htm
Jan 03, 2008 | TruTech TT1620 DVD Recorder
PROGRESIVE SCAN
I have the samne problem, hoiwever when I press the menu/setup button it says setup on the display but nothing changes on the tv, it does not have a navigation menu, any suggestions on what to do to remove the progressive scan from my screen
Nov 05, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Sudden split screen
Your dvd player is in progressive mode, and your tv isnt capable of playing progressive mode.  To fix this, look on your remote for a button called "Progressive", and press it.  If you dont have a button like that, then look through your service manual for anything that says progressive mode, and it should give instructions on how to set it back to interlace mode.  This is a very common problem I come across when servicing DVD players, as inadvertently pressing the wrong button the remote will cause this.
Sep 07, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Arris DCT700 DTV Receiver Logo
149 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
