Question about Rancilio Classe 10 Espresso Machine
Continous lights flashing on rancilio
All lights flashing on machine when in use
Can I regulate the temp on our machine? our Rancilio machine seems to be to be running on too high a temperature. Meaning, we barely turn the steam wand on to steam milk (after the light goes off), an
Silvia has two bimetalic switches that control the boiler temperature. One for brew water and one for steam. They are not exact and they can go bad. They are cheap and easy to replace. Just Google for Rancilio parts.
A much better fix (and more expensive) is to switch to PID control. Google for Rancilio PID control. The conversion is $250+ but once you've gone PID, you'll never go back. The temperature is exact, fast, and totally under your control.
Jan 12, 2015 | Rancilio Silvia Espresso Machine
Intuita coffe machine not working
Needs a service take it in let them replace the seals,If the seals go faulty this happens
Dec 29, 2013 | Coffee Makers & Espresso Machines
LPG operated usually fine but drops pressure after a couple of hours continous use in our coffee van. Pressure will rise again after 10 mins or so. How do we stop this from happening? Jan
You can do one or two things;
1 - Increase the pressure stat to 1.3 bar,
2 - Raise the water level in the boiler for more thermal mass so that you do not lose as much heat when the machine adds water to the boiler.
Jul 05, 2011 | Rancilio Classe 6 Espresso Machine
New rancilio epoca s tank I turn on the switch 1, the boiler is filled and is activated. ok once the boiler is filled i turn resistance switch 2 ...but it doesnt work.
It should take about a 1/2 hour to warm up, are any lights flashing? Is the light on the second switch green? If not you might want to take off the left panel and find the thermal reset. Its mounted to the top side and has a little red button facing you. Press that to reset the unit.
Mikey@espressomachineexperts.com
Feb 24, 2011 | Rancilio Epoca ST-1 Espresso Machine
The rancilio coffee machine failed to heat up no steam or hot water but all switch lights work and water pumps through
Remove the top panel, and check the thermostats on the boiler there are 3 of them. One needs to be reset.
Aug 09, 2010 | Rancilio Silvia Espresso Machine
Why has my rancilio silvia v3 steamer stopped
Remove the top panel and check the 3 thermostats there, one of them tripped.
Jul 16, 2010 | Rancilio Silvia Espresso Machine
Rancilio epoca 2 head machine. Lights are flashing in a line (like arrow) on both sides. pressure is up a little on one side, but not other. water is cold,
Machine is not heating, the lights should flash until it heats up to 1.2 bar on the top gauge. If not check the water level in the machine and check the red reset switch to see if the thermostat tripped.
Jun 28, 2010 | Rancilio Classe 6 E 2 gr Espresso Machine
Switch lights not turning on
There are about 3 of them under the top panel.
Jun 19, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Rancilio Classe 10 Espresso Machine Logo
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
