Hp printer d7260 error code 0xc 18a0001
Printer stuck on error code 0xc18a0001
4 Suggested Answers
nandosnut
  • 112 Answers
SOURCE: error message 0xc 180001
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on.
If it then turns itself off again, turn it back on; it should start the calibration sequence (it takes about 5 minutes) and when it finishes, you should have a working printer again!
Posted on Apr 26, 2009
pineworks
  • 4041 Answers
SOURCE: problema con errore 0xc 18a0301 HP Photosmart
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 04, 2010
  • 100 Answers
SOURCE: ink system failed error 0xc 18a0001 printer will
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Posted on Jan 23, 2011
Error Oxc 18a00001
you may need another print head with that error code message. I would contact HP Total Care (1800-474-6836) and check to see if your printer or print head is in warranty, and it could be replaced.
Error 0xc18a0001
Jan 20, 2016 | HP Photosmart D7260 Printer
HP 3210: Fehler Oxc 18a0001
The only way to fix Oxc18a errors is to reset the printer. You can find the instructions on www.inkbank.com.au website here:
HP ink system failure error HP maintenance error what to do if HP printer...
Jan 01, 2015 | HP Photosmart 3210 Printer
Ink system failed error 0xc 18a0001 printer will not function
Jan 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
0xc18a0001
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Jun 02, 2010 | HP Photosmart 3210 Printer
Hp c7180 getting message ocx1a002f, any ideas?
Are you sure the error code is not 0xc....
It sounds like your C7180 has an internal error condition and may need to be reset. It may be easier for you to view this solution online from HP support:
An 0x.. error message displays
Dec 21, 2009 | HP Photosmart C7180 All-In-One InkJet...
Error message 0xc 180001
Apr 24, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Printer D7260 Printer error
i do not have areason for why the printer continuously goes offline but there is a way to put it temporarily back online. Go to printers in the control panel. right click on d7260 and click on use printer online. This only seems to work for one or two docs before you have to repeat the process.
Nov 16, 2008 | HP Photosmart D7260 Printer
k24674
jasbo
jasbo
