Question about Sewing Machines
JanomeTroubleshooting Janome Model SUV 1108 stitches are uneven. Troubleshooting suggests needle is incorrectly installed. I don't think so but in order to remove the needle from the needle clamp to check, instructions are "Loosen the needle clamp screw by turning it counterclockwise". It's very tight & will not move. Any suggestions? Help.
mallow1
  • 35 Answers
SOURCE: material doesn't move
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
Posted on Aug 16, 2008
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
SOURCE: needle clamp fell off. got a new one, but need
I have an XL6452 and the same problem. I figured out that you can use a tiny screw driver (or an allen wrench might work). I tried using the screw that tightens the needle but it didn't seem to work. The screw looks like it just a hole. It took a lot of turns to get it loose enough so you can put it on. You will see it come out.
Once you get it on you can tighten it.
Posted on Feb 13, 2010
  • 1788 Answers
SOURCE: Can't loosen screw holding needle in sewing machine
Use a penny or a nickel in the screw head. Works like a charm
Posted on Jul 26, 2010
Testimonial: "Thanks!"
bugoy31
  • 1238 Answers
SOURCE: Stitch tension problem - bobbin
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on Jun 17, 2011
Janome 11000 skipped stitches if any are even made at all
Skipped stitches sometimes occur if the machine is incorrectly threaded. Remove the thread and re-thread from the beginning (first RAISE the presser foot so the thread will seat in the tension disk).
Confirm that the thread follows the correct pathway (consult manual).
Try installing a brand-new needle.
Make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues to not pull up the bobbin thread, the needle/hook could be out of time. May require service.
Sewing machine won pick up bobbin thread hook timing fix
Mar 05, 2016 | Janome 11000 Memory Craft Special Edition...
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
Janometroubleshooting
If you took the bobbin case out to clean, make sure you put it back correctly. This is very easy to not put back correctly, also make sure the bobbin is wound correctly. Sometimes, I use air spray like for computer cleaning and use it in the bobbin area and threading area. All you need is a little spec of dust to throw it off.
Mar 31, 2014 | Janome America Inc 6500P Memory Craft...
checks that the strip wire and strip wire sensor, this worked well.
(the strip threads is the small spring by which you spend the thread to thread)
Jan 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
try changing the needle
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
My Janome Memory Craft 4800 is skipping stitches. I've cleaned the bobbin race, replaced the needle and re-threaded both top and bobbin. Any suggestions? it also feels as if the thread is getting caught on...
Here are some things to check.
* Thread tension is too tight.
* Needle is bent or blunt.
* Needle is wrong size.
* Needle and thread does not match.
* Light pressure on presser foot.
* Incorrect setting of needle.
I hope this helps you.
Sep 18, 2009 | Janome Memory Craft 4800QC
No stitch happening
May sure you are using the correct size of needle and thread suitable for the fabric. make sure the thread in the bobbin and the needle is of the same weight or size. Make sure the needle is changed often - after the completion of an garment. After much use the needles become blunt and cause problems with your stitches.
Also, if the bobbin is jamming that is normally because the machine is threaded incorrectly, or the bobbin case thread is wound unevenly, or the bobbin case is not put in properly.
Try this! Just stop for a while, give yourself a few minutes to relax. When you return pull the User's Manual and slowly go over the instructions, especially the "troubleshooting" section. Also, rethread the machine and the bobbin case by carefully following the steps in your User Manual. I have found that it helps me tremendously when I have problems. Hope it help. Happy Sewing
I have similar problems
Aug 02, 2009 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
