Question about Sony KDL Televison & Video
SOFTWAR PROBLAME IN SONY KDL 46W904A
SOME TECHNICAL PROBLAM IN MY 3D LED IN MY DATA CARD AFTER UPGRADE
  • Sony Master
  • 3,904 Answers
You may have to upgrade the firmware to the data card. Go to the card manufacturing website to get the info.
Posted on Nov 18, 2013
5 Suggested Answers
cene765
  • 787 Answers
SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Posted on Nov 16, 2009
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
  • 2386 Answers
SOURCE: does my Sony KDL-46NX700 play 3D?
Hello
You can play 3D on it, it has 3d comb filter but this is not complete 3D TV, for more information visit HERE and see specification
Posted on Feb 14, 2011
  • 430 Answers
SOURCE: Sony kdl-46w4150 standby blinks 8 times
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
Posted on Feb 12, 2012
SOURCE: LCD Screen replacement for KDL-55HX800 55in 1080p 240Hz 3D LED TV?
Hi there and good morning to you
I am sorry I do not know of anyone apart from trying AMAZON.
Here in Iceland Imight eventually find one but it is far away.
Good luck toyou
Kolbrun
Posted on Feb 25, 2012
Do you have a manual I can print off?
Sony has the manual for the KDL-50R550A on the product support site: https://esupport.sony.com/US/p/model-home.pl?mdl=KDL50R550A&template_id=1®ion_id=1&tab=manuals#/manualsTab . Look in the left hand column under Manuals for the Operating Instructions; if you don't see that heading, click on the Manuals, Specs & Warranty tab. The current direct link to this manual is https://docs.sony.com/release//KDL-R520A_R550A.pdf . You should be able to print the file from Adobe Reader or a similar program.
I hope this helps.
Jan 21, 2016 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
What does 4-blink error code indicate?
These may help - the first just tell what it is and which ICs maybe the problem (quite technical)
Solved Sony Bravia Blinking Code
Bravia KDL46EX720 Red LED blinks 4 times and TV wont turn on What is the...
or, in the last resort you could try Sony support, either to get a service manual, or to ask a technician. Don't be fobbed with an expensive answer as in one the examples above.
Support for LCD TV BRAVIA Sony
18.November.2015
Nov 14, 2015 | Sony KDL-46EX720 BRAVIA 46 Class LED 3D...
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Sony TV KDL-40EX720 is faulty!
From your video, it looks like a mainboard, Tcon or cable issue.
You can try to contact 40 diag LED EX720 Series Internet TV Sony to see if they have spare parts for this. Those three items above I would target as the main problems.
Feb 12, 2015 | Sony 40 BRAVIA KDL-40EX720 Full HD LED 3D...
How can i register add Sony TDG-BR250 3d glasses to SONY KDL-70W850B 3d tv
Hi Mate
Press the Power Button of your 3D glass for 2 Seconds The Power Goes to Green LED ON now your 3D glass is ready for used. Play your 3D movie from Bluray player and Press the 3D Button on the remote. If there is no 3D button on the remote then press Option Button on the TV remote and choose the 3D option from the list. the video will changed to 3D video Now Enjoy your 3D experience. If you any difficultes then PM me.
Dec 11, 2014 | Sony Bravia XBR KDL-70XBR7 70 in. LCD HDTV
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
Oct 05, 2013 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
Good luck toyou
Kolbrun
Feb 25, 2012 | Sony KDL55HX800 55 in. TV
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
Nov 16, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
Televison & Video Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
