Question about Startech VS440HDMI 4x4 HDMI Matrix Video Switch Splitter with Audio an
3d ghosting When i run a 3d video over the matrix its ghosting, however when i directly run the 3d video without the matrix theirs no ghosting.
    New Friend:
What you need is HDMI Matrix that supports 3D formats. Also, the ghosting could be coming from low grade HDMI cables and used for good quality of HDMI Matrix and HDMI cable products with 3D support.
Posted on Oct 28, 2014
Is the splitter rated for 3d??
Posted on Nov 17, 2013
How do you get it out of 3d what do I adjust, its not a 3d tv
This is an color projector alignment issue. Many projection TVs have a menu item in the video or picture setup that will produce a grid overlay on a black screen of Red, Green and Blue. You use the <, >, up & down buttons on the remote or the TV to move each color (one at a time) directly on top of each other and maintain straight up and down / left and right lines. Once you do this, the picture will be in focus and there will be no more colored "3D-like" ghosting. If you are unable to move the colors far enough, there may be an issue with certain integrated circuits inside the TV that can be challenging to remove and replace. More make and model number for your TV would be required however.
May 21, 2014 | Televison & Video
Yamaha RX-V471 3D video for blu ray will not display on TV
Your Yamaha is the problem here. It cannot handle the signal and process the 3D as it states. What I would do is hook your player direct to your TV in the manner that it works and feed your audio from a different path to maintain surround system. Your tv/dvd player may have an audio out that you can feed back to the Yamaha .
Jan 11, 2014 | Yamaha Rx-v471 3D A/v Receiver
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
The screen is showing a ghost or double picture
Does the picture look 3d? colors out of place and or skewed?
If it does, go into the customer menu with the Sony remote and select convergence----if red or blue are warped and will not move in some direction--you have a common problem---CONVERGENCE.
Confirm model number and tell me if it is 3D like picture.
I can if it is tell you what is needed to fix it--I am here to help people and I do this here for free.
Regards, SD TECH
Oct 30, 2009 | Televison & Video
Playing video audio through car stereo Toyota Matrix
You're probably gonna need a wired FM modulator. That part will take an audio output and run it into your antenna plug on your radio. It will use a FM channel, but it's wired directly to your stereo. So no static as found with wireless FM transmitters.
Jan 20, 2009 | Audiovox AVD300T Car DVD Player
Ghost images on the screen
sounds like the two stk392-560 ic's need to be changed, usually about $400 for the parts and labor
Mar 14, 2008 | Sony KP-51WS510 51" Rear Projection...
Startech VS440HDMI 4x4 HDMI Matrix Video Switch Splitter with Audio an Logo
362 people viewed this question
Top Startech Computers & Internet Experts
David Payne
David Payne
Are you a Startech Computer and Internet Expert? Answer questions, earn points and help others
