Question about Whirlpool LSR5132J Top Load Washer
Replacing lid switch for whirlpool washer LSR5132JQ0
I need to replace the lid switch for a whirlpool washer. I don't know how to open the the washer to get access to it. And I'll need instructions on how to replace the switch. Any help and pictures on how to would be greatly appreciated. Thanks, DW
  • Anonymous Dec 09, 2007
    Need to replace lid switch and don't know how to get access to it.
  • antonella11 Jan 28, 2008
    i have the same problem any solution
  • 126 Answers
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
Estate by whirlpool model SM8280867. Filled, then stopped. What's wrong?
Charla, By what you have stated, it sounds like a lid switch failure. I recommend checking the screws for the lid hinge first.The lid has to be closed for the motor to run in the washer. If the lid switch is faulty, it will act as if the lid is open. A quick check you can do is to run a cycle with the lid switch jumped. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console.Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and white wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Then start the washer in a cycle, and let it go. If the washer completes the cycle, you need to replace the lid switch. Remove the jumper and order the part. The jumper is only of the test do not continue to operate after test.
Whirlpool Appliance Parts
Whirlpool Appliance Parts Whirlpool Appliance Parts from Easy Appliance...
http://www.repairclinic.com/Shop-For-Parts/a11b5/Whirlpool-Washing-Machine-Parts
Mar 05, 2016 | Whirlpool Washing Machines
Washer fills up with water but does not start to wash/agitate
if you don't hear the motor running you have a bad lid switch,if you do hear the motor but no agitation you have a broken motor coupling.
most likely you have a broken lid switch,close the lid,then open it around 6 inches,close it and open it a few times,as you do this if you don't hear a clicking sound the switch is bad,part number 8054980 and it's around 25 dollars.
http://www.youtube.com/watch?v=PZAbg9uftos&feature=BFa&list=PL946F2AC904989088
watch this video, when you click on it look down on the left side it will say replacing new style,click on it and it will show you your model.it will show you how to make sure it's the lid switch but if you don't hear any clicking when you open and close the lid the switch is bad,also if the lid is pushed in from putting the laundry basket on top of it open the lid and wack the center of the lid to pop it back up,i've done this before when the lid is dented in and this fixes the problem,the arm that's connected to the lid doesn't hit the switch correctly with the lid dented in but usually the switch is bad and needs to be replaced.
http://www.youtube.com/watch?v=MFsvLiuTniU
watch the first part of this video and it will show you how to open the top console,this is different from your lid switch this is just to get you into the top so you can change the switch.good luck,if you need anymore help let me know and i hope this helps you out
May 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 - will fill but no cycle or drain, can hear the timer running
Apr 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi Dennis! I have a whirlpool ultimate care II washing machine. It agitates, but will not drain or spin. any suggestions?
Check your lid switch, you should hear a click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 17, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Replace lid switch on whirlpool type 111 washer
The following link explains step-by-step how to repalce a lid switch on your washer:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
I hope this information helps you. If you have any questions, please let me know.
Dec 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do i open the entire lid of washer to repair switch?
The following link explains step-by-step how to replace the lid switch on Whirlpool top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Oct 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
what brand machine? whirlpool take off the cabinet and the switch is on the rhs under the lip
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Question about whirlpool catalyst 27" washer
F3 means lid switch failure. Heres what the service manual for your washer says about the failure.
Flashes if the lid is NOT opened after the cycle was completed. The
electronic control board must detect that PAUSE/CANCEL was
pressed during a cycle or the lid was opened at least once at the end
of any cycle. This is continually tested to ensure proper lid switch
operation. If “F 3” is flashing, check continuity of the lid switch.
• With the lid closed, lid switch contacts should be closed.
• With the lid open, lid switch contacts should be open.
• If the lid switch has failed, replace it.
• If the lid switch is good, replace the electronic control board.
Apr 05, 2008 | Washing Machines
Washing Machines Logo
790 people viewed this question
Dan Webster
Dan Webster
Sal De
