Question about Avanti Fitness AT580 Light Commercial Treadmill
Avanti at580 error-7 what is it?
T mill starts working but after 1 1/2 min er-7 come up
What does the F 1 display code ? The cooler isn't working On avanti model WC681BG-2
I tried to see what the F-1 Code is but found very little information other than talking to Avanti Customer Service 800-220-5570
You most likely have other problems when a error code is showing. Here is a user manual=> HERE
Appliance 911
Jan 02, 2016 | Avanti Refrigerators
I Have a whirlpool dishwasher du1145 first I got an error message er s. Now it will turn on changes to quick wash starts at 48 min runs for about 2 mins then changes to 99+ runs for about 10 min then get...
Have you consulted the user manual for troubleshooting tips? When having problems with appliances or whatever, please consult the user manual first as they have a troubleshooting section for this purpose. If like some, this was discarded you will either need to contact the manufacturer Customer Service or their support website. Anyone beyond that for support should be a last resort.
Please get well acquainted with this site. Go here now please.
http://www.whirlpool.com/support/
Apr 29, 2014 | Dishwashers
Er 1 error
Dear Sir:
adjust the speed sensor, see the diagram attached, clean, and tight the connector very well.
2) Test the input voltage motor, if there are the motor need repair or replace.
3) Test the output voltage from the main motor board for the input of motor, if there are NOT, the board is faulty.
4) After fix it, run the software calibration, for diagnose, and troubleshooting.
sincerely. God bless you
Apr 24, 2012 | Avanti Exercise & Fitness
Wont work AT380 AVANTI tred mill - comes up EJJ SOMETHING OR OTHER PUSH BUTTONS DONT WORK
ADJUST THE REED SWITCH ACCORDING WITH DIAGRAM.
NOW TIGH THE FLEXIBLE CORD FROM KEYPANEL VS DISPLAY BOARD AND THEN CONNECTOR FROM DISPLAY BOARD VS LOWER BOARD OR MAIN CONTROLLER BOARD.
11_30_2011_12_40_41_am.gifIf you can open the keypanel and clean with contact cleaner will be a good idea with carefully and patience. sincerely.
Finally if the problem persist you will 2 options: a) faulty display board and 2) Main controller board.
E.CUADRA
MANAGUA, NICARAGUA
Aug 21, 2011 | Avanti Fitness AT380 Treadmill
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
How do you open and refill a Trudeau 7-1/2-Inch Manual 2 Mills In 1 slat and pepper mill? We though out the directions.
any mills i have seen either have some type of plug in bottom or screw apart some way
Oct 11, 2010 | Microwave Ovens
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Avanti Fitness AT580 Light Commercial Treadmill Logo
Top Avanti Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Avanti Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
