Question about JVC GR-DVM50 Camcorder
How to get a video you accidently deleted on an elgato hd capture card
How come on my Elgato Game capture HD for mac i can never get audio comming through my computer on any system
1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
You can refer to this article for more details:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
When using the Xbox 360, you can refer to this article:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/configure-audio-settings
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital Stereo My Elgato Game Capture HD doesn
Jun 21, 2014 | EyeTV Elgato Game Capture HD High...
In My Elgato Game Capture HD on ps3 i have A colour (tint/hue) problem it wont fix
The tv is not the problem it's the elgato, during the setup it changed settings on the PS3. The problem can be fixed by changing display settings on the elgato software.
Aug 11, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
My new Elgato software is saying it has no signal yet I've hooked it up correctly. Help!
  • try checking what the cable is for usb tv or ps3 video ?
  • El Gato have good support help i use to use it for video productions, way back
Nov 23, 2010 | Elgato Systems Elgato Video Capture...
Elgato EyeTV (T5301LL/A) Video Capture: I have an old camcorder - with only a yellow video...
If you have just one Audio Out RCA jack then the camcorder only recorded in MONO, so all you would need to do is either plug the wire coming from your single Audio Out jack into the left or white input jack of your Capture Device which may have an option in the software program to set it to recieve audio in MONO, or you can buy a RCA Jack Splitter that goes from a single Female RCA jack on one end and 2 Male RCA Jacks on the other end. Then you take the end of the Splitter with 2 plugs and plug one of them into the White Jack and the other into the Red Jack on your Capture Device, and the other end with just one plug should plug into the cord coming from the Black Jack on your Camcorder.
May 16, 2010 | Apple Elgato EyeTV (T5301LL/A) Video...
No instructions! do i need a lead to detect tv signals?
By "TV" Signals, do you mean video signals? If so, the WIndows video player does a good job of playing most varieties. If you mean off air or cable TV signals, you'll need a receiver. Look at the Elgato, or similar brands. They plug into a USB port and are capable of receiving analog and/or HD ATSC signals, or cable signals. Keep in mind that digital cable signals are generally a mess to identify and sort out because they are on different digital channels and subchannels. You may need a digital to analog converter in front of your Elgato to keep from going nuts trying to fighure out where everything is.
Nov 14, 2009 | Computers & Internet
I accidently deleted all of the videos on my Flip HD Mino while trying to save to my PC. Can they be recovered and how? Thanks
You may try this camcorder video recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your flip HD Mino memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
you may follow this video tutorial
May 14, 2009 | Pure Digital Flip Video Ultra Camcorder
JVC GR-DVM50 Camcorder Logo
46 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
