Question about Motorola Mobility RAZR V3
White screen` Okay... this is going to take me a little so hang in there please... -first the phone went though a time where it would power down (like restarting) while I was on the phone. -sometime last week, the screen went completely black (both the inside and outside screens). The phone still worked, i could make phone calls by dialing the number and pressing talk, but NOTHING would show up on the screen. But then the next day, the phone fixed itself (the only things I tried was powering it on and off and playing with the battery). _NOW, two nights ago, the screen went black for a few hours. NOW the phone turns on and off, and I can make calls in the same 'dial then press talk way', but the difference is that the main screen is white and the little screen is blue. I tried pressing between the camera and the volume keys, when I did that, the screens went completely black and scared the **** outta me before it went back to the white screen. I also tried taking the cover off the flip side and playing with the flex cable (the white one) I disconnected it, reconnected it, played with it in every possible way....and my screen is stikll white. ANY IDEAS!?!?!?! I'm desperate right now!
  • 3 more comments
  • Mike Armstrong
    Mike Armstrong Nov 15, 2007
    I have the same issues with my razr phone. I have the white screen on the inside panel and the blue screen on the outer panel, this was intermittant for a while now it's all the time.
  • spicylatina Jan 07, 2008
    my phone is the same danm thing!!!.... im so frustrated at it its been doing it for about 4 months now.i havent bothered to go see a store about it or anything because the warranties out but ive only had it for a lil over a yearnow, any sugestions for me also ?
  • lkparra Mar 09, 2008
    Same terrible white screen here. I only had the camera for a couple of weeks, and one day when to the white verizon screen, and I can't get it to shut off unless I take the battery out. This model def has a glitch!
  • Anonymous Mar 09, 2008
    yea i have the same **** problem it is makin me so ****** off i wanna break ma phone in half i turn it off and on now im switchn batteries with an old razor someone help!!!
  • hvabarg Oct 03, 2008
    today i was charging my phone, but i did not get to charge it all the way. i put it in my purse and was on my way, went for a walk and came back to see if anyone called and all i had was a white main screen. now my front screen will work but it looks wiggley. and my main screen is still white
    New Friend:
  • 8 Answers
I have the same problem, theres nothing you can do, just get a new phone is it. =/
Posted on Nov 02, 2008
Hit hard with hammer and buy a new phone.
Posted on Aug 30, 2008
I hhave the same problem. my phone is white SOMETIMES but when i turn it on the screen is blurry. im pissed off because i dont know how im going to get all my contacs back. i'm getting a new phone today :] but im worried i wont get all of my contacts back. id ont want to take the phone apart and that stuff but i really need help. if someone could reply VERY FAST!!!! please please please do :]] it will be greatly appreciated.
God BLess
Posted on May 17, 2008
I was having the white screen problem and what seemed to fix it was to take the back panel off, remove the battery and clean the connections.
Posted on Apr 23, 2008
  • darlinnefari
    darlinnefari Feb 21, 2013
    Did you clean it WITH anything?
The white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Posted on Jan 15, 2008
There are where you Sim Card is at is probably loose. That causes the phone to restart!
Posted on Nov 07, 2007
SOURCE:
How so i get rid of the "white screen of death"
Hold down power button for about 30 seconds (or until phone recognizes power off), let it shut down.Afterwards, hold power button down maybe 10 seconds, release and let it reboot. If it performs normally, great. If not, check the following page:
Fixed HTC Stuck At White Screen of *****
Sep 13, 2017 | HTC Sensation 4G
My Nokia 6233 Hangs & Then Shuts Down.
check the side button PTT
and make full reset
May 11, 2010 | Nokia 6233 Cellular Phone
I'm using MSI P4MAM-V (P4MAM-V) motherboard. I have 2 problems...
change the bios battery.. if it is done. than this is motherboard level problem.. You need to take it to motherboard technician...
Mar 23, 2009 | Computers & Internet
My wing has a blank white screen with a black scratch
i think your solution to your problems is the T-Mobile Wing Flex Cable that must of gotten cut.it is the ribbon cable that allows you to move lcd up and down, the installation of replacing the cable is very hard if you dont know what your doing, trust me your lcd is not broken.
Jun 14, 2008 | T-Mobile Wing™ Smartphone
PLZ HELP SIDEKICK 3 SCREEN WENT RED AN GREEN
reylakers-
You can try and reset the flex cable on the lcd.
follow these instructions.
Fix Sidekick White LCD Screen
If that doesnt work then a new lcd screen unit will.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Screen went white
did you leave the power on? try to turn it off than on again okay
Jun 05, 2008 | Coby MP-C7085 MP3 Player
Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Jan 29, 2008 | Nokia N95 Cellular Phone
White screen on Motorola RAZR
I use to work for Cingular Wireless and this happened often. Try opening and closing the handset a little forcefully. It should re-seat the screen onto the contacts. If that doesnt help, have it replaced since its new. Best of Luck.
Sep 05, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Screen went white
Have you tried removing & re-inserting battery and power back on the phone?
Sep 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
969 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
