Machine trouble service call 13dd - Office Equipment & Supplies
Please my fellow enginneer how can I clear (13DD)code on c20 konica minolta
Your missing the EPROM chip you should have taken it off the old board when you replaced with the new one. it holds Serial number, counter info so people can not make it zero and it be used. 8 pin chip
Mar 10, 2017 | Konica Minolta Office Equipment & Supplies
How will i fix bizhub c20 when it show 13dd
you replace a circuit board and there is chip on the board missing.
Nov 01, 2016 | Konica Minolta Office Equipment & Supplies
Model C20. what can i do to clear code 13dd?
Did you replace the main board??if so the a Chip is missing which is required on the board, have the old board if so remove from old place on new board.
Apr 25, 2016 | Konica Minolta bizhub Office Equipment &...
How do i fix error code 13DD ON KONICA MINOLTA BIZHUB C35
The counter data on one card does not match counter data on a different board did some one try to reset the counters to make the machine newer???? Need to get tech out to try and rewrite the firmware,
Jun 30, 2015 | Konica Minolta Bizhub C35 Multifunction...
How do i fix error code 13DD IN KONICA MINOLTA BIZHUB C20
GET a tech out to see if the firmware can be rewritten or boards may need to be replaced.
Jun 30, 2015 | Konica Minolta Bizhub C20/x Copier
Konica MInolta 1690 Printer Machine Trouble Service Call 0001
check all image units and fuser also check the transfer belt, something is stopping th main transport motor replace the all ave worse case motor is burned out along with main control board$$$$$$$$$$$$$$$$$$$$$$$$$$
Dec 30, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Sep 13, 2009 | Konica Minolta bizhub 180 All-In-One...
Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Jul 16, 2009 | Konica Minolta Di1610 Copier
Trouble shooting guide
You can dowload one from LaMarzoccoUsa.com
Apr 24, 2009 | La Marzocco Linea Series Group 3 Espresso...
67 people viewed this question
k24674
