you have a defrost problem, timer ,heater or bimetal most likely. if its a whirlpool i would suspect the bimetal, take off the back wall of the freezer, thaw the frost off, look for a metal cylinder clipped to the evaporator, it has a plastic cap, if it looks like the cap is coming off or tilted that is mostlikely the problem, if its a ge i would check the heater, post back a model number, located inside the ref section, wall or ceiling, not door. and i'll try and give more feedback. hope this can help.
The defrost heater is not working. It is a heat glass tube and 99
percent of the time - the problem. It is controlled by the defrost
relay which is controlled by the defrost timer.
Remove the rear freezer cover and inspect the heater tube. You can usually see a break n the internal heater filament.
The internal light stays on and the fridge bleeps even when doors shut the problem seems...
(More)
The internal light stays on and the fridge bleeps even when doors shut the problem seems intermittent but happens regularly every day , sometimes consistently then will stop for a while.
Side by side fridge has a bad odor in the fridge side. Removed all shelves and drawers and cleaned...
(More)
Side by side fridge has a bad odor in the fridge side. Removed all shelves and drawers and cleaned the interior. Pulled the fridge back from the wall and inspected the underside and cleaned. Still smells bad. Has a sulfer type odor. Any thoughts?
samsung fridge / freezer power freeze button and light keeps going on and off and it keeps beeping....
(More)
samsung fridge / freezer power freeze button and light keeps going on and off and it keeps beeping. how can ifix this?
Just started recently and all of a sudden. Fridge is about 7 years old. The door dispenser drips...
(More)
Just started recently and all of a sudden. Fridge is about 7 years old. The door dispenser drips once a second or so. Had to cut the water off to the fridge. From reading around, it sounds like maybe a valve is not shutting tight enough? Is there a separate valve for the icemaker (just curious)? Where is this part and is it easy to replace? Note... This machine also won't give whole ice cubes, only crushed - hasn't for years and I've just lived with it. If you happen to know how to fix that, let me know. Thanks!
