Question about Kenmore Sewing Machines
How to adjust sewing machine model 385.16528000
Adjusting needle on quantum LE singer sewing machine model SX
What do you mean by "adjusting" needle? There is only one correct way of installing a needle. There is no adjustment available, that I'm aware of anyway. Perhaps you are using the incorrect needle for your machine.
Apr 04, 2017 | Singer Sewing Machines
How to fix the timing on a Singer model 9410?
There are several components to the timing of a sewing machine and any one of the 7 adjustment points could need to be adjusted. I have found the link below very helpful with my 25 machines that I have for my business. They are really great to work with and very helpful. Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Feb 03, 2015 | Singer Sewing Machines
Singer 7462 will not pick up bobbin thread
You need to adjust the needle timing - called "timing the needle".
How do to that is usually included in the service or repair manual for your model of machine. There are various online shops where you can order this.
Also, the machine is pretty similar to the Single 7422, and there's an ehow article on how to adjust the timing on that model that you might find useful.
http://www.ehow.com/how_7799647_adjust-singer-7422-sewing-machine.html
Dec 01, 2013 | Singer 7462 Mechanical Sewing Machine
My machine model is 2405, i placed some thread on the bobin and placed it back. unfortunately the thread on top does not join the lower thread, what shall i do?
the sewing machine probably needs to be serviced to see if the
machine needs to be timed or maybe some adjustments need
to be made.
Dec 31, 2012 | Sewing Machines
How adjust the hilo in the sew machine singer model 3116
Please read your manual and watch the dvd, or call Singer at 1-800-4singer. Their website is www.singerco.com
Jun 16, 2010 | Singer 3116 Simple
The dog feed stuck in the downward position.
Have you turned the machine off and then back on?
The switch may be broken and you will need to find a sewing machine repair shop that repairs all brands of sewing equipment.
If you decide to purchase another machine try a different brand. This one seems to have on a lot of issues.
Feb 19, 2010 | Sewing Machines
How to adjust preasure on Kenmore Sewing Machine
Hi, not knowing which model # Kenmore it is its difficult to answer. Some have button on top to press down, some had the adjustment inside the left cover and probably other ways I could look up if I knew what model you had.
Rick
Mar 22, 2009 | Kenmore Sewing Machines
Can't adjust button hole width
Only the stitch length is adjustable in Buttonhole mode on that model.
Jan 02, 2009 | SINGER 7470 Sewing Machine
Sewing Machines Logo
20 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
