Question about Samsung ES30 Digital Camera
The lens will not oper fully and turnes off input new batteries in it and tried again but still the same
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
When I turn my DMC-TZ3 on, the lens open's up then shut'soff then open's again then shut's off again and a message appears saying shut camera off and try again, will not stay open why is...
A recycling lens is usually caused by either a low or worn out battery (how old is your battery? If more than a couple years, it would be definitely time for a new one. Here's a selection.). If a new battery doesn't help (but it really does sound like you need a new battery), the next problem that could cause this is a lens error. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
When I turn my camera on, the screen is black and makes beeping sound? Also lens is stuck
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Cameras
My Sony DSC-W230 turns on and lens keep opening and closing, and then it shows "turn power off and on again". how do i fix this ?
This sounds like a stuck lens. Here is a good blog about things to try to fix it:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The blog is about a lens error, but when the camera lens opens and closes, there is often a problem with the lens.
Also make sure the battery is fully charged, and good. Also make sure the contacts are clean on the battery, and also inside the camera.
If all fails to get it working again, get an estimate on repair first, since the cost can justify just going ahead and buying a new camera.
Good luck, and hope this helps.
Aug 01, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Z740 easy share will not power up,tried new batteries ,nothing at
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
Sony Mavica MVC-CD400 will not operate under battery power.
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Aug 31, 2009 | Sony Mavica MVC-CD400 Digital Camera
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Samsung ES30 Digital Camera Logo
65 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
