Question about Ovens
Burner warning light between the burner switches will not go off
    Prodigy:
    An expert who has answered 500 questions.
  • Ovens Expert
  • 650 Answers
I assume this is an electric stove or cook top. In the switches there is a contact that when the switch is turned on the contact sends power to the pilot or warning lamp. One of these switches is more than likely the culprit. You will have to make sure the power is off and check each switch until you find the one causing the problem. It may be better to have a service tech do this if you are not familiar with these switches and their wireing.
Posted on Nov 20, 2013
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
The left front burner on my stove heats up when it is not in use. It is an electric stove.
Hi Teresa Rhodes- Smith -Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, I strongly suggest contacting a professional to move forward accurately and to assist with the repairs and to refrain from using the unit. The range could possibly be experiencing a communication error with the EOC, wiring failure, or faulty element sensor/switch.
Jan 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Gas burner will not light
First thing is to check the burner cap and the area to make sure its clean enough for gas to flow properly. Next turn the switch to see if the electrode is sparking for that burner. If not then either the infinite switch or the spark module are bad
May 28, 2012 | Whirlpool Ovens
Burner ignighter will not stop clicking. The burner is not lit, but the clicking will not stop
One of the 4 burner control switches on the front of each burner control valves has failed. Inside the thin ceramic switch there are 2 thin strips of copper that are pushed together by a rotating cam driven by the movement of the burner control knob. One of the thin strips is stuck together.
UNPLUG the unit and only plug it in briefly for testing.
The top has to be opened by removing all 4 burner caps and removing the 4 screws under the burner caps. Remove the caps completely but reconnect one burner cap and make sure it is grounded so you can test the igniter's. The gas burner tubing needs removed then the gas burner support has to be removed to gain access to these switches. To remove the wires from the switch you have to use a jewelers screwdriver to release the 2 wires from the switch one at a time. The switches are in series parallel so if one switch is stuck all 4 igniter's pop. To read out the switches you have to remove at least one wire from each switch and insert a short test wire to read for continuity, The switch that has continuity with the burner control switch OFF is the failed switch.
NOTE: the yellow and orange wires need to be insulated during testing. I use a folded paper bag or torn off strips of a cardboard box Just test briefly....
The part number for the switch is 7403P190-60 (Image search)
http://www.repairclinic.com/PartDetail/Switch/7403P190-60/2326
There are numerous sources for the switch.
Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Magic Chef Ovens
After I turn off the top electric burner the red light does not go off.The burner is cold but the light remains. Is it safe to use even if the light does not go off and the burner is cool?
Yes it is safe to use. One of the switches has a malfunction on the pilot portion of the switch. It should be replaced,but it is not dangerous.
Sep 18, 2009 | GE Ovens
Large range burner switch possibly defective
no warranty only 12 mo. The switch is bad call dealer - servicer and order part. should be less than $50
Apr 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Gas Burner spark on other location
When you turn a burner to the light position, all burners should spark. If one is not, clean burner head area where the burner is not sparking. (dirty from boil overs)
Sep 02, 2008 | GE JGRP17 Gas Single Oven
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
