Question about Gateway 7210GX Notebook
Pcmcia cards show up as mtd-0002
The pcmcia cards all show up as MTD-0002. All solutions i found so far revolve around bios prob with soundblaster. The version of bios On this laptop doesnt have any place to diable any onboard items or any other options other than Video mem and hard drive boot order is Phoenix bios 57.06.07 any ideasa
  • 661 Answers
If you go into sound and multimedia you can change the preferred output/input items to your PCMCIA card rather than the onboard systems. you could also try disabling onboard systems in device manager too.
Posted on Oct 09, 2007
SOURCE:
Pcmcia mtd 0002 driver download
try www.driverscape.com/download/pcmcia-mtd-0002
Dec 12, 2013 | Computers & Internet
I need and MTD owner's manual Model #2 Serial #
You manual can be found here:
http://manuals.mtdproducts.com/mtd/Public.do?model_num=2&serial_num=472612&doSearch=Y
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Mtd Garden
Mtd tiller is dripping oil from the main case
possible leaking from seal on side of engine around shaft,mine does and on further inspection found shaft inside engine to be worn where it goes through outside cover.
Jul 12, 2009 | Mtd Garden
Smart card holder not working
if you want a installer visit @ (www.hp.com)..good luck
Jul 10, 2009 | Computers & Internet
MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Jun 05, 2009 | Mtd Garden
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
PCMCIA MTD-0002 problems
ADDRESS BAR: PCMCIA MTD-0002 DRIVERS
WWW.DRIVERSHQ.COM/DRIVERS
WWW.WINDRIVERS.COM
WWW.PCMCIA.COM/DRIVERS
MANUFACTURE NAME,MODEL,MAKE DRIVERS.COM
Dec 13, 2008 | Gateway 7210GX Notebook
Pcmcia mtd-00002
Please use this webpage to download the newest uptodate drivers from Dlink
http://support.dlink.com/downloads/
If that doesnt solve the problem, let me know.
Mar 16, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Acer & Win2k new Device PCMCIA MTD-0002
Try using this Unknown Devices program to identify the hardware. Then search the internet for the correct driver.
If this does not solve the problem then check with the computer manufacturer for a BIOS upgrade that could repair the problem.
The manufacturer's web site may also have documentation that identifies this unique problem.
Dec 30, 2007 | Acer Aspire 5630 Notebook
Open Questions:
See all Gateway 7210GX Notebook Questions
Gateway 7210GX Notebook Logo
443 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
