Question about Canon Imagepress C1 Color Copier, Printer,q2 Print, Aa2 Finisher, Low Meter
When I turn on my canon ImagePress C1+ printer it stays in warmimng up state and never gets ready. what is wrong? how can I fix it?
When i turn my conon imagepress c1 printer it state and this error code come it e00001 - 001 what the problem and how can i fix it
Posted on Dec 27, 2013
I have a machine canon imagepress C6011VP with error E00000-0201-05
hi if u get error E00000 as main code that's mean the heater problem
u should have to check the hater lamp and the thermal fuse in fixing unit if every things are good this is only malfunction just reset error code.
Oct 27, 2014 | Office Equipment & Supplies
E000110-0210 CANON C3220-C1
Code E110-0210 Description The operation of the laser scanner motor is faulty. The rotation of the M laser scanner motor is faulty.
The motor lock signal remains in an unlock state for 1 sec or more while the laser scanner motor is in operation. Error Codes Canon iRC3220 Code E110 0210
Oct 29, 2013 | Office Equipment & Supplies
Canon ImagePress C1 cannot calibrate from Windows 7
The problem is it doesn't recognize Java 7. Install Java 6 (latest version) and it will work. You can have both Java 6 and 7 installed at the same time. As well make sure if you are running a 64bit machine you install the 32bit version of Java (so you will have 4 versions installed). Java 7 32 & 64 bit, Java 6 32 & 64 bit. I had the same issue and solved it this way.
Jul 26, 2012 | Canon Imagepress C1 Color Copier,...
Waste toner canon imagepress c1
if it is the 2nd transfer cleaning waste toner, you have to clear copier-counter-misc-2TC-Box
Jun 10, 2012 | Canon Office Equipment & Supplies
Error p08
Repair, Canon MP258 code error P08
1. The printer is off and plug the power cord.
2. Press the button STOP / RESET and hold, then press and hold the POWER button
3. POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed
4. Release both buttons simultaneously
5. The printer will proceed in a while, then the LCD panel will show the number zero (0)
6. Computer will detect NEW DEVICE (Canon MP258 series Printer (Copy 1)), Ignore it
7. Press the power button, then the printer will turn off. If the printer does not turn off, unplug the power cord.
8. Press the power button again, then the printer will be ready to use.
Nov 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error e020 0180 on canon imagepress c1 please give me a reply
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Dec 19, 2010 | Canon CLC 1120 Color Copier
Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
Dec 10, 2009 | Office Equipment & Supplies
I have error code E000732-0001 on Canon imagepress C1
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
Canon Imagepress C1 Color Copier, Printer,q2 Print, Aa2 Finisher, Low Meter Logo
144 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
