Question about Oster Microwave Ovens
Manual for microwave model# OGF41101
Can I turn the sound off on my Oster microwave the model number is OGF41101
5 Suggested Answers
SOURCE: Oster ogf41101 light on, table
Blown High voltage fuse. 5000 volt .83 amp
Im going to replace mine and see what happens
Posted on Apr 10, 2011
rickead1
  • 1998 Answers
SOURCE: Oster 1.1.cu.ft countertop microwave model
check the high voltage fuse on the inside of the unit if this is not showing a fault then you would most likely be looking at replacing the magnetron in your unit this is the most common piece beside the fuse that shorts out and is what is directly realted to what is actually heating your food depending on what type of microwave it is it may be cheaper to just buy another microwave if the place of origin on the microwave came from a walmart or target store where as buying a magnetron may cost you between 50-100 dollars which is about the price of a micro wave at one of these stores if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Posted on May 23, 2011
caroldon
  • 17130 Answers
SOURCE: Oster ogf41101, unit display doesn't work, when
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jun 14, 2011
  • 12 Answers
SOURCE: OSTER MICROWAVE 1.1 MOD OGF41101-RUNS BUT WON'T HEAT.
There are two fuses in a microwave oven, and for the non-heating problem the problem is the high voltage fuse, incapsulated between the transfo and the magnetron. This supports up to 5000V and usually rated something like 0.65A/0.7A/0.8A and even 1A.
When you open the capsule, you'll see it sitting there between its two connectors, and you'll notice the filament inside the glace is broken. Buy a new one and your machine will work like a horse.
NOTE: Try to get the same ratings fuse, or else the oven will smoke and smoke the house with it, so be careful.
The other fuse is smaller, and usually ceramic one, which can be found on the PCB, if that goes, you should get no power at all to the machine. If not sure, let a professional do the job, it's safer.
Posted on Apr 07, 2013
OK, so, my Oster Microwave, model # OGF41101 stopped heating. I've got the cover off and the fuse out but I noticed a small "what is it" mounted on the top of the inner cabinet with obviously charred
YOU GOT IT - LANDFILL!
Actually, had built in over the stove microwave, that "JUST STOPPED" working one day.
I looked around. You can get a good new Microwave for a very low cost these days (yes, it won't last forever, and will be more landfill - but that's how they make things these days)
Try dealnews.com - it constantly updates, and I got an awesome deal on a new microwave (with free shipping) must be 5 or so years ago ... it's still working great .... and I use it a lot.
Sep 18, 2014 | Microwave Ovens
Oster microwave model ogf41101 all works but dont
you can use a 250vac 20 A ceramic fuse but the right size is engraved in one end of the fuse any radio shack or electronic store will have it make sure it is disconnected.
Aug 29, 2014 | Microwave Ovens
Torn wave guide
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You didn't mention your brand or model number, but since you posted under Oster, I'll assume that's it.
You can contact Oster via the information in your owner's manual or get their contact information from the dealer where you purchased the oven.
Nov 27, 2012 | Oster 0.7 Cu. Ft. Compact Microwave
Jun 14, 2011 | Microwave Ovens
Oster 1.1.cu.ft countertop microwave model OGF41101 stopped heating
May 23, 2011 | Oster Microwave Ovens
Oster ogf41101 light on, table turns, does not heat anything
Feb 27, 2011 | Microwave Ovens
Oster bread machine manual
Hi and welcome to FixYa, I am Kelly.
You did not mention a model number so I guessed. Here is the manual for the 2 LB machine:
http://www.oster.com/manuals/oster/005838-000-000_English.pdf (58 minute machine)
This is for the other machine:
http://www.oster.com/manuals/MANUALS/CKSTBRTW20_43_33506787.PDF
All Oster manuals are on this page:
http://www.oster.com/ProductManuals.aspx
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Microwave Ovens
I NEED MANUAL FOR OSTER MICROVAVE MODEL #OM1201EOVG
You can call 1866 257 3336. Oster is now part of Sunbeam. They will email a manual to you, free.
Aug 12, 2010 | Oster 0.7 Cu. Ft. Compact Microwave
Need manual for Oster microwave model 0mw1199 1.1 cu. ft.
Try this...
http://www.curtisint.com/html/custservice/manuals/OST_OMW1199_EN.PDF
By the way, in case you ever need to search by your model number, the first digit is the letter O, not the number zero.
Nov 14, 2008 | Microwave Ovens
Microwave Ovens Logo
93 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
NOEL
NOEL
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
