Question about Freezers
Temp display flashing FF, OF, and O. - Freezers
  • 44 Answers
What brand , is this on the freezer door ? Possible error code or reset function. More info please.
Posted on Nov 19, 2013
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What can I do? Freezer is not cooling, inside light is on. control panel is off, Temp shows blinking OF and FF
Might need a freon top up. If the compressor is functioning there may be in sufficient freon . This can be topped up. A repairman/technician can diagnose this fairly quickly
Jun 05, 2015 | Frigidaire Freezers
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
Frigidaire freezer display flashing of and ff. I can't get it to do anything else.
Hello Aaron, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating your freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Nov 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer says FF after it kept beeping. I unplugged it and plugged it back in and it hasn't helped. What else can I do? The temp was 25 degrees
Google your problem with the mfr. and the code ff and it will give you solutions. Do this if you don't have a manual or call dealer.
Feb 09, 2013 | Freezers
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
My Chestfreezer is displaying FF
I believe the FF would mean a thermistor has an open circuit . If so then the sensor would need to be replaced .You can ohm the sensor and at room temp it should be around 1100 ohms.
Always disconnect power before attempting to repair any electrical appliance
Oct 21, 2017 | Freezers
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
163 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
