Question about Samsung DMT400RHS
Heavy and smart auto flashing - Samsung DMT400RHS
Samsung dishwasher not finishing was cycle flashing smart auto and normal lights at same time and not draining out water please help
http://www.appliancepartspros.com/diy-story-error-code-over-fill-flashing-smart-auto-diy916377.html
Apr 22, 2017 | Samsung Dishwashers
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
Nov 23, 2015 | Samsung Dishwashers
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Why on the Samsung DTM400 series dishwasher are normal heavy and smart/auto lights all flashing?
That's a High-temp Heating Error. It's usually caused by a bad ECS sensor. You will need to call a professional repairman to replace it. (I recommend Sears).
Aug 17, 2014 | Samsung Dishwashers
Why does the Heavy and smart auto lights flash simultaneously after cycle starts?
It means "over-level water error". Usually caused by a bad case-brake assembly.
Jun 05, 2014 | Samsung Dishwashers
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
I am using a candy cty 105 smart. The machine doesnt seem to finish the cycle I washed at 60 and at the end the symbol for heavy solied flashed and the start symbol flashed. I havent used the machine...
i had this problem to.. my solution for this was the wire of pump. wire was just unpluged i just re entered the wire end all was back to normal.. :P
Jan 24, 2010 | Candy Washing Machines
Samsung DMT400RHS Logo
289 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
