Question about Car Audio & Video
Jensen UV7i DVD troubles
I installed a Jensen UV7i DVD deck in my Chevy yesterday, and it worked like a champ. Now when I use the CD or DVD player, it is very loud in the drivers side speakers, and the volume wont adjust. There is also a loud boom through the speakers every couple of minutes. When I switch to the radio function every thing is normal. WTF? I pulled the unit out and everything is connected as per the givin wiring diagram.
SOURCE:
  • 24 Answers
SOURCE: Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Posted on Mar 07, 2008
SOURCE: Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at [email protected]
Posted on Mar 28, 2008
SOURCE: 2002 Chevy Cavalier audio wiring diagram
to the guy who is looking for the wire diagram, you can buy a wire kit for the stereo connection for about $60 from best buy or some other place like that. your car's door ding and some other things wont work with out it. hope that helps you some.
Posted on Sep 08, 2008
SOURCE: KEH P4750 wiring diagram
I hope this picture is worth thousand words for you
Picture tells about the power input and the sound input.
Posted on Sep 21, 2008
SOURCE: Jensen UCH 6006 cd changer
This is the wiring diagram for the RF modulator. Not sure if this helps or not - the wire colors should be the same as what you are asking for.
Posted on Dec 17, 2008
Hi there, have just purchased a car with a jensen in dash dvd player. it came without a manual and we are not sure how to use it properly. how can we source a manual. also does it have a plug in for...
Is there a part number of the In Dash DVD/CD? I mean I could pull a manual would give you a hint how to use the deck.... This is the best I can do without knowing the model number of your deck... Hope this helps
http://www.docshare.com/doc/225137/VM9510-Manual
Sep 23, 2010 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Bad disk
Wow! That's a first. I used to sell both the Jensen AND Phase Linear versions and never a problem. It sounds like a bad unit. You say it plays NOTHING? No CD's OR DVD's that are the factor made?
The only thing I hav up my sleeve is to do a reset on the unit. If it has a button (I don't think it does frm what I remember) use it first, then with the unit ON, unplug the poer plug, wait a few, then plug back in and see.
Sorry I have no more tricks foir that,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Wiring uv7i
you can use the deck without a remote, the only thing is you cant go into the system without the codes. there is a sequence code you must enter to disable it. there are a couple of videos on youtube but none for the uv7i. trust me, i 've been there on and off since the summertime. i am not sure if the sequence works due to me not hooking it up to external monitors but you can disable the blue screen with a on/off switch...only problem is, you'll have to do it everytime you turn your car on. here's what you do....
buy a on/off switch(radio shack $3)
hook the pink wire to one part of the switch-the other to the negative ground
put a dvd in(from what i hear, it must be store brought), wait unntil the blue screen comes up
turn the switch off...wait two seconds/turn on...wait two seconds/turn off...wait two seconds and turn back on. the blue screen is gone and video is on. ifyou still need the diagram, i'll scan mine for you.
Nov 09, 2008 | Phase Linear UDV9010 Car DVD Player
Jensen uv7i
did you try resetting the unit?
May 29, 2008 | Jensen VM9510 Car DVD Player
Jensen in dash dvd/mp3
PUT IN A DVD FIRST AND THEN PUT IN THIS CODE (543210) HOLD DOWN THE 0 FOR 4 SECONDS.
Jan 16, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv7i
Dec 28, 2007 | Alpine CDA 7893 CD Player
UV7i Jensen Audiovox In Dash DVD
Run a Lens cleaner kit on it. That is one of those Discs with a coth like material that can be lightly soaked with a cleaning fluid. You can get them at WalMart or Game Stop
Nov 29, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
