Question about Canon Office Equipment & Supplies
I have canon IR 2420 copier first it say 000805-0000 when solve this problem it say again 000197-0000 , what is the main problem?
IR 2420
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
fer_nan_14
  • 76 Answers
SOURCE: copier model canon ir 2016 (down load stand by )
hi if yo have knowledge on electronics try to remove the boot rom and memory and let the machine for 10 minutes,then put it back the memory and boot rom,and turn on the machine.if the same thing try to update the firmware using sst
Posted on Mar 06, 2009
hi how do solve this problem system error E007
Posted on Apr 09, 2009
  • 117 Answers
SOURCE: canon iR 2016 copier problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Posted on May 07, 2009
SOURCE: how to solve to check printer cover in canon IR
how to solve to check printer cover in canon IR 1610 copier
Posted on Jul 05, 2009
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
Canon 2420
replace the imaging film,get a tech to do it
May 27, 2015 | Canon Office Equipment & Supplies
Code Error on Ir 2420 l display **E000003-0000 what can i do please solve this...
dear
pl. do check the fixing film assy. heater strip contact points. if corrosion clean/replace it.
Check the DC card.
Also check the supply voltage at the machine input.
Thanks.
Dec 04, 2014 | Canon Office Equipment & Supplies
Update firmware to ir 2420
BIOS MODE wait updating F/W for canon ir 2420
May 26, 2014 | Canon ImageCLASS MF4370dn Laser All-in-One...
E0000-001 de canone ir 2420
Fixing unit temperature rise detection (by main thermistor)
May 23, 2014 | Canon imageRUNNER 6020 Copier
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
64 people viewed this question
old marine
old marine
