Question about Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV
My pioneer tv and receiver are both stuck on standby mode how do i get it off?
The receiver and the tv are stuck on standby the power button will not turn on on the tv
  • 41 Answers
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
  • 197 Answers
SOURCE: will not power up fully
power supply call pioneer
Posted on Jun 07, 2009
SOURCE: my brandnew Pioneer PDP-5020FD won't turn on.
Check page 9 of this document:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PDP-5020FD_OperatingInstructions0610.pdf
You will see that there is a power button on the bottom right corner of the back of the unit (item 25). Turn the unit on using that first.
Posted on Aug 10, 2009
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
My Pioneer PDP508XDA tv is stuck in standby mode since a power outage
try unplugging and then hold the ower button in untill all lights go out. plug back in and try to power on.
Apr 13, 2014 | Office Equipment & Supplies
Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Amp err
Same problem here VSX-916 AMP ERR
Jan 28, 2009 | Pioneer VSX-D912 Receiver
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Pioneer Receiver will not come on
press and hold the enter button on the amp then hold the power button down whilst holding the enter button still do this for about 10 seconds then it should reset its self
Apr 29, 2007 | Pioneer VSX-D411 Receiver
Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV Logo
21 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
