Question about Cell Phones
Intex Neo v. Why does it have white screen? - Cell Phones
I want to restore my intex neo v+ .but I have forgot my password.
Hi Manoj, The link below is a YouTube page full of videos showing how to factory reset any laptop, I hope this helps...... CHEERS.
how to factory reset any laptop YouTube
May 10, 2016 | NEO Computers & Internet
How can i get rid of jarring sound from my intex 4.1 hometheatre? the jarring sound peaks when i increase bass/main volume levels
You are approaching the cutoff level and getting distortion.
You you have too much amplification or too strong of input signal.
You can can turn down compression or turn up attenuation on the receiver and check other Dolby or neo settings from your manual. Or, don't turn it so loud.
May 08, 2014 | Audio Players & Recorders
No display when turned on
if you recently turn on the laptop but the screen doesn't show up not even a just a white screen then probably the power connection of the screen is broken, if just a white screen and no other display then you have a broken flex, a ribbon cable, other posibilities is that you might have a busted laptop. try removing the battery and plug directly to your power cable, long press the power button until you see led light turning on,. if your still not sure, you better bring it to a techinician, or to the store were you bought it if it still has the warranty.
Apr 04, 2014 | NEO Computers & Internet
Cause of vertical collapse on glendale tv chassis
collapse means just a white line left to right in middle of screen--usually a bad solder connection at the vertical output chip or a bad part in that area.
Nov 07, 2012 | Televison & Video
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
R4i Neo Card for DS Lite - Mario Kart
I had the same problem.
download the http://www.r4neo.com/Firmware_upgrade.rar
to upgrade your nds firmware then it will work
Dec 05, 2009 | Nintendo DS Lite Console
I have an R4i Neo card in a DSlite. Mario Kart
Pokemon White wont play on my dslite but al other games work. when is start up pokemon white both screens turn blank and the only thing that works to get this screens away is tto turn off the ds.
could you please help me with this problem i want to play pokemon white
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
