Question about Sportline 345 Electronic Pedometer
PSE Mach Flite 4 Owners manual
Cam part numbers for 28 inch draw
MTD Snow Flite model 316230500. Where can I get belts?
I have already answered you twice with this information!
They have there own forum.
http://www.snowblowerforum.com/forum/mtd-snowblowers/1397-mtd-snow-flite-snow-blower.html
You don't need the part number, you just need to measure the length, or you can phone and say;
I have a snow flite brand snow blower model.316230500. Serial no.811262, send me a belt for it.
All the belts are here
http://www.jackssmallengines.com/equipment/mtd/snow-blower/belts
and here
http://www.mtdparts.com/equipment/mtdparts/parts/machine-types/snow-throwers
Dec 24, 2015 | Garden
What is draw weight?
Generally, the draw weight is the amount of force to pull the bowstring to a certain draw length. The industry standard is measured in pounds at 28 inch draw length.
Aug 26, 2012 | Betsey Johnson Archery
My pump blew need a new one which one is it
In the event you do not have a manual, though it sounds like you do, you can find one at this URL:
http://www.powr-flite.com/text/powr_pdf/manuals/extractors/PFX1350_Manual.pdf
The location and telephone number of the company is at the bottom page of the URL. They are located in Ft. Worth, Texas and should be able to provide you with the information and part you need.
If this solution is of help to you, I would appreciate a Thumbs Up.
Be well. Paul
Oct 05, 2010 | Powr Flite PFX1350 Upright Steam Vacuum
How do you set camshafts on an 1986 harley davidson 883
you have to install cams #1, #3, and #4 first. Time cam #3 and #4 with each other. The final cam to install is #2 and the marks must line up with cam #1, cam #3, and the pinion gear.
This is one of the cases where a picture is worth a thousand words. If you'll contact me directly at wd4ity@bellsouth.net, I'll scan a drawing in and e-mail it to you. I cannot do that on this forum. Maybe they'll add an 'attachment" feature on day. Remember to tell me what you need, a drawing of the cams. Do you know how to tell which cam is which? I.E. which cam is number 1, which is number 3, and so on? If not, let me know that as well.
Good
Aug 17, 2010 | Harley Davidson XLH Sportster 883...
Tornado wide area commercial vacuum
Hi There,
Your Tornado Wide Area vacuum cleaner is actually manufacturered by Powr-Flite. The two companies are sister companies, and owned by the same parent company Tacony.
It sounds like to me that your belt may have broken, or fallen off of the motor shaft. This may explain why the roller brush is not spinning. There is also a reset switch on the machine, on the top (item # 41 in diagram below), you should check the reset switch first. Try pushing down on this switch to see if this will restart your brushes.
If it doesn't, here are instructions on how to open up the belt, and inspect it or replace it if it's broken:
If you need to purchase a new belt, you may contact Powr-Flite at 1-800-880-2913, and request them to send you part number 19802.
Here's links to the instruction manual, and parts diagram for your Tornado, which is the same exact machine as the Powr-Flite model PF2030:
Owners Manual & Parts Diagram
If you have any follow up questions, please don't hesitate to ask using the add a comment form here on the Fixya repair page. If you have any problems ordering from them directly, feel free to contact us, and we'd also be able to provide any parts for you.
Here's how you may contact us:
http://www.govacuum.com/info.html
Thank you,
Chris Jones
GoVacuum.com
Apr 16, 2010 | Tornado 93030 Wide Area Carpetkeeper...
I need a manual for the Delta band saw model number 28-207
Go to this link, Right click on the underlined PDF below the Publication Preview, and you'll be able to save target as a pdf file onto your system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 03, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Need a manual for a delta 28-150
Go to Dewaltservicenet.com and in the middle of the page type in your model number and you can look at a breakdown or manual
Mar 03, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Sportline 345 Electronic Pedometer Logo
163 people viewed this question
Top Sportline Sport & Outdoor - Others Experts
Are you a Sportline Sport and Outdoor - Other Expert? Answer questions, earn points and help others
