Question about GE Monogram ZE2160SF Convection / Microwave Oven
When microwave opened automatically turns on
As soon as I open my microowave to put food it the fan turns on and the turntable starts to turn, I don't remember this happening before. does this mean I am being exposed to harmful "microwaves" while opening door? thanks
  • jsumanis Dec 05, 2007
    Thanks for the suggestions. I took it into the shop and it was a bad door switch.Thanks
  • GE Master
  • 9,098 Answers
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 26, 2007
  • 473 Answers
Sounds like it has a bad door switch. I would unplug the unit and have an experienced technician check it out. Microwaves can be very dangerous if you don't know what you are doing.
Posted on Oct 07, 2007
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Jul 29, 2014 | Whirlpool GH7155XHS Microwave Oven
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
I have a model number EM925RSL-B and the timer counts down but it does not heat up or turntable does not move?
I just bought an RV with the exact same microwave and the exact same problem. The problem with mine is the switch that detects that the door is closed is not getting activated. The reason for this is is the finger at the top of the door is damaged as well as the plastic piece that the finger grabs onto when the door is closed. This causes the finger not to come into contact with the switch. To test this you can turn your microwave on and start it. open the door and using a small screwdriver, depress the micro switch you can see upper right side of the door opening. then press start again. your turntable will start turning and the microwave will make a louder noise as a fan will turn on. CAUTION! Release the button as soon as you see the turntable rotation as you will be receiving microwave energy due to the door being opened.
Jul 02, 2011 | Microwave Ovens
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
May 30, 2008 | Sanyo EM-S8000 Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Monogram ZE2160SF Convection / Microwave Oven Logo
117 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
