Question about Epson WorkForce WF-3520 All-in-One Inkjet Printer
All lights are flashing on front display
Machine turns on then after 30 seconds all front panel start flashing and nothing works
I reseated all the ink cartridges, unplugged the network cable and turned the printer off and on again. Once it stopped making noises, I plugged the network cable back in again and it worked fine.
Posted on Feb 25, 2014
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
My lights are flashing on my Kenmore Washer machine HE3 110 Series. How do i reset it?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 20, 2009 | Kenmore HE2 Plus Front Load Washer
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
Front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Washer stuck
May 01, 2009 | Kenmore 42822 Front Load Washer
Lights on Washer Machine flash but Washer doesn't work
Mar 31, 2009 | Kenmore Washing Machines
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore He4t- pushed cancel to add at start of load, now nothing but flashing lights
The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Sometimes this is all that is required to "cure" momentary "glitches". If this does not fix your problem, please post back and let me know. Hope this helps you.
Sep 11, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch Nexxt Premium WFMC6400UC does not start with the following status: Start/Paus light blinking Display says ready Pressing start does not do anything I have done the following: Holiding the Start...
A faulty module or timer/control panel. Unless you are getting some form of error code in the way of flashing lights or otherwise. In which case refer to manual. Good luck.
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Epson WorkForce WF-3520 All-in-One Inkjet Printer Logo
285 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
