Question about Asko 1595 Dishwasher
F2 display on Asko N516 dishwasher - Asko 1595 Dishwasher
SOURCE: How do I reset an F2 warning on my dishwasher
Hold in the start stop button till it resets
Posted on Dec 11, 2009
  • 351 Answers
SOURCE: Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Posted on Apr 09, 2008
  • 351 Answers
SOURCE: asko dw95.4 dishwasher flashing f2
remove the dishwasher from under the bench and tip it back to let the water run out from underneath,remove the rear panel at the bottom and run test for leaks or blockages.
Posted on Oct 09, 2008
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
SOURCE: My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Posted on Jan 19, 2010
Pump continually running with F2 displayed.
There is water in the lower pan that you must access by removing the toe kick plate and then the panel behind it. you will see water in the overflow area. Clean that out and all will be well. Asko's are awesome dishwashers that capture any water they may overflow or leak internally instead of it going on your floor, then a float switch triggers the F2 error and runs the drain pump.
May 30, 2012 | Asko D1716 Built-in Dishwasher
I need a manual for my dishwasher ASKO N516 type: DW 20.2
I went to the Askousa website and located manuals for your model, the link below will direct you to select your current model, you can download all your information and manuals from this site.
I hope this helps
www.askousa.com/customer-care/technical_documentation/
Aug 14, 2011 | Dishwashers
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
MY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Sep 10, 2009 | Asko Dishwashers
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Dishwashers Logo
52 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
